Old 03-01-2009, 09:50 PM   #1
Ford Assassin
Ford Assassin's Avatar
Question Brake Conversion Hard Line Question.
Hey guys, I spent this weekend ditching the stock from drum brakes in favor of some discs (still not done though). I bought a spindle/rotor kit from McGaughty's.
Anyway, my truck was a manual drum setup, however I have a decent used booster and master cylinder from a '71-'72 C10 including the disc brake proportioning valve that I want to use. After looking at my current hard lines exiting my drum/drum proportioning valve its clear that the rear hard line isn't going to work with the disc proportioning valve because the existing hard line would need to make a 90* bend and I fear the old line would bust in the attempt.
So, what are you guys using that have done this swap?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 03-01-2009, 09:57 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Brake Conversion Hard Line Question.
I have the exact setup your going with, however I am not running a booster. You are more than likely going to have to custom bend your own lines.
Your best bet is to spend $50 at NAPA on a KD double 45 degree flaring tool. Get several scrap pieces of brake line and practice. practice, practice.
I know it sounds intimidating, but once you get the hang of it, you won't be sorry.
here's my routing:
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-01-2009, 11:02 PM   #3
Pont406
tcb-1,
nice set-up. Where did you get a prop valve?
Pont406 is offline   Reply With Quote
Old 03-01-2009, 11:15 PM   #4
americanmusc1e
americanmusc1e's Avatar
Thanks!!
I just completed my swap last week and my hardline bent fine but i needed an adapter to go from the '70 rear hardline to the '72 proportioning valve (went to 4 different auto parts stores and finally found it at NAPA) if you need the specs on it let me know.
BTW: I didn't know they changed the brake line routing from '70 to '71. the '70 lines were routed under the engine, the '71 lines were routed in front of the engine
here is the link to my disc brake swap thread, hope it helps
http://67-72chevytrucks.com/vboard/s....php?p=3169908
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-01-2009, 11:23 PM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
The lines were still under the engine, however on 67-70, they stayed behind the x member out to the wheel, on 71-72 they went under the motor mounts and up the front of the cross member. You may be thinking of 73 and up trucks that routed the brake lines behind the very front x member.
If your kit uses 71-80 calipers, the easiest way to go is to order the brake line set for a 71-72 truck from inline tube. It should have everything you need. You will have to fab up a bracket for the end of the hardline where the rubber hose connects at each front wheel. I like to cut the existing one off the back of the x member and tack it on the front.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-02-2009, 12:41 AM   #6
Ford Assassin
Yeah, if you have that Napa part number and/or specs it would be great. I have a tubing bender, I just haven't attempted it yet.
Thanks!!
Cable
Old 03-02-2009, 07:29 AM   #7
tcb-1
tcb-1's Avatar
pont406,
thanks. the prop valve is a CPP part# PV-1
ford assassin,
I searched the NAPA website but couldn't find the exact pn#. you may call up your local NAPA and ask them if they have the KD Tools brand, 45 degree double flare kit. I can get the actual KD part# tonight if you need it.
Doug
Old 03-02-2009, 11:01 AM   #8
Ford Assassin
I think you misunderstood. I can get the bender, I want to know the adapter part number.
Cable
Old 03-02-2009, 01:35 PM   #9
tcb-1
tcb-1's Avatar
oh, your talking about the line to line adapters, right? if so, I got those at NAPA as well. just took the two mating tubes or threads in and I was gold.
Doug
Old 03-03-2009, 12:51 PM   #10
americanmusc1e
Thanks!!
the recipe is at my house, i'll get it for you tonight if i remember
-- Josh
Old 03-03-2009, 08:47 PM   #11
americanmusc1e
here is the NAPA part # for the bushing for the rear brake line going into the proportioning valve
G49502-0303
-- Josh
Old 03-04-2009, 12:34 AM   #12
Ford Assassin
Change of plans, I called ECE and asked Mark what they do for conversions and as it turns out they have an adapter they call the "Candy Cane" that will connect to my rear line and extend and bend the line to fit into my '71-'72 proportioning valve. $15 to my door and alot less hassle.
Thanks anyway guys!!
Cable
