Old 03-02-2009, 12:24 AM   #1
kcackler
Fuel Tank sending unit
Got a 77 chevy scottsdale and need to replace the sending unit on it. It's mounted on the passenger side. Do I need the 2 outlet unit or the 3? (I don't have the truck with me, but would like to have the part when I pick up the truck) Also - Since I'm going to be down there anyway, would it be beneficial to replace the fuel pump? Not sure how long it's supposed to last..
kcackler is offline   Reply With Quote
Old 03-02-2009, 01:07 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Fuel Tank sending unit
Depends. Standard half tons with light duty emissions have the 3 tubes. Big 10 or Heavy Half trucks with heavy duty emissions just had 2.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-02-2009, 01:27 AM   #3
kcackler
Thanks for the info.
Blue - 77 Chevy Scottsdale
Old 03-04-2009, 10:32 PM   #4
vtwinsport
vtwinsport's Avatar
You only need two really, one for breather line (could be routed to charcoal cannister), one for fuel to pump.
My 76 silverado had 3 on the passenger side with dual tanks. I dumped the drivers side as it had a leak and no proper filler hose opening. Trashed the cross over hose and extra wiring (related to tank switch) underneath and ran new hose to pump. Hope that helps.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 03-04-2009, 10:58 PM   #5
kcackler
I've already ordered the 3 tube unit. Are you saying that either would work in my case? (Single tank passenger side)
Old 03-05-2009, 08:20 AM   #6
vtwinsport
vtwinsport's Avatar
Yes, either will work. Since you ordered the 3, you can plug the 3rd with a hose and bolt.
Old 03-05-2009, 11:14 AM   #7
kcackler
Cool.
Thanks.
