Old 03-02-2009, 12:36 AM   #1
chev-obsession
chev-obsession's Avatar
Right Stuff brake lines
im doing a disc brake conversion and i bought the brake lines from right stuff... any ways im getting ready to install them, and i was wondering if anyone had advice or pictures of how they might go on.
chev-obsession is offline   Reply With Quote
Old 03-02-2009, 09:13 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Right Stuff brake lines
what do you need pictures of? brake line routing? what type of conversion did you do (switch front crossmembers) , or replace rotors etc.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-02-2009, 07:21 PM   #3
chev-obsession
i need pics of how they are routed, all of them(rubber brake lines to where they are mounted onto the braker master cylinder.
Old 03-03-2009, 12:36 AM   #4
John H.
John H.'s Avatar
Attachment 436880
Attachment 436881
Attachment 436882
Name:  72 GMC 003.jpg
Name:  72 GMC 007.jpg
John H. is offline   Reply With Quote
Old 03-03-2009, 12:43 AM   #5
John H.
John H.'s Avatar
Name:  72 GMC 011.jpg
Name:  72 GMC 016.jpg
The front lines on the 71-72 go on the front of the cradle as the drum lines go on the rear. You will need to fabricate a bracket where the hardline attaches to the hose. You can cut off the bracket on the rear and bend and drill a hole in the bracket and cradle to mount. You will need to route the lines first, then determine where the bracket needs to be mounted. You can see a little from these pictures.
Old 03-03-2009, 12:45 AM   #6
chev-obsession
Thanks thats a lot of help fo me! would it be too much trouble to take a pic of where the brake lines mount up to the master cylinder?
Old 03-03-2009, 12:51 AM   #7
John H.
John H.'s Avatar
Name:  GMC 1969 007.jpg
The rear goes in the back of the Prop valve and the other line goes underneath. I had to shrink the file to get it to upload so it is a little harder to see. This is a 69 with 71-72 brakes. The pictures I sent you were from my 72 w/19K original miles.
I will see if I have some of the bracket mounting shots for you.
Old 03-04-2009, 01:16 AM   #8
chev-obsession
allrighty thanks! i will take some pics of what im having issuses with tommorow after school.
Old 11-04-2016, 10:10 PM   #9
mattfranklin
mattfranklin's Avatar
John H., I know this is an old thread, but your pictures are incredibly helpful for what I'm doing today. I appreciate your taking the time to take and share the pics.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 11-05-2016, 07:40 AM   #10
John is a good guy. It's nice to see a fellow member go out of their way to thank another for being helpful. We could use more of that here.
Originally Posted by chev-obsession View Post
...rubber brake lines...
Those are known as brake "hoses".
* Lines = metal (rigid)
* Hose = rubber (or other flexible material)
