Old 05-12-2002, 08:03 PM   #1
72MARIO
72MARIO's Avatar
Cool Sway bar ?
hey I got a sway bar off a 71 C20 and I was wondering if this is the biggiest one you can get . I think the size is 1 1/16 sound right? trying to get the right size for new bushings from energy susp . also is anyone using the lowered sway bar bracket from early classic?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-12-2002, 08:09 PM   #2
tom hand
CCRider
tom hand's Avatar
Post
The stock one is pretty small. If you want a bigger one, get one off a 3/4 ton 73-up truck,it will bolt right on. When I lowered my 71 I mounted the sway bar directly to the frame.with no brakets except the ones that go around the bushing.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-12-2002, 10:58 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
supposedly the 3/4 ton burbs had even larger ones, but i had an 85 one and it had the 1 1/16" one also, i would look for 1 ton trucks of later years up to 87 and see. I think the largest there would be wouldd be 1 1/4", if evne that much.
1 1/16" will make a hugeeeee difference in the truck's handling alone.
good luck
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-12-2002, 11:14 PM   #4
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Post
72 Mario; Thats the same size i have on my 72 3/4 ton custom camper .
72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings
tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40.
Torrance Calif.
" If I knew I was going to live this long I would have taken better care of myself "
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 05-13-2002, 09:26 PM   #5
Duallie
Duallie's Avatar
Post
My 3/4 ton front bar is 1 1/8, and the swapped-in bar on the ramptruck is the 1 1/4" 1 ton bar. I used greasable polyurethane for the frame bushings, but have to use the factory rubber for the A-arm because the poly can't handle the swivelling and gets spit out, in my experience.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 05-13-2002, 09:33 PM   #6
BobM
Post
I picked up a 1 1/16" bar off a 75 Chevy at a wrecker for $20 bucks. Totally different handling truck. Best $20 bucks I ever spent.
BobM is offline   Reply With Quote
Old 05-14-2002, 12:00 AM   #7
68Custom
Hammer On!
68Custom's Avatar
Post
So whats the normal for a 1/2 ton sway bar? i tried to get a bushing set from autoparts store and they said there were 4 different ones for our style trucks? Gotta have the right dia. i guess.....
Aaron (68Custom)
1968 C10 Custom Long Wood Bed
New Crate 350/TH400, PS, PB
*50th Anniversary Pickup*
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 05-14-2002, 01:59 AM   #8
basketcase
basketcase's Avatar
Post
Mario,
I'm using the Chevy 1 1/16 bar with Polygraphite greasable bushings and lowered mounting brackets from Early Classic. Nice parts and powder coated. Fit perfectly but you have to remove the lower rivet in the front spreader crossmember if your truck was not factory sway bar equiped. The lowered brackets keep things up out of harms way while maintaining the proper angle to the contol arm brackets.
One more thing. The former GM at Guldstrand Motorsports, The Corvette suspension people, told me to use marine grease on the poly bushings. It won't wash away and will keep them from squeeking.
Tom
[This message has been edited by basketcase (edited May 14, 2002).]
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 05-14-2002, 07:55 AM   #9
71Chev
71Chev's Avatar
Post
A correct 1/2 ton sway bar for our trucks is 1", the 3/4 ton is 1-1/16th".
  • 71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 05-14-2002, 03:39 PM   #10
72MARIO
72MARIO's Avatar
Post
Thanks i will order the lowered swaybar bracket soon it will end up costing 50 or 60 bucks bye the time it gets here CAnadian FUNDS SUCK the exchange rate sucks !!!!!
2005 TAHOE DD
Old 05-14-2002, 03:39 PM   #11
72MARIO
72MARIO's Avatar
Post
2005 TAHOE DD
Old 05-14-2002, 05:18 PM   #12
72step
72step's Avatar
Question
I'm getting ready to install a sway bar in my dropped truck too. Should I opt for the $25 at the wrecking yard, or buy one from classic performance for $150 with the urethane bushings and all? And are rear-sway bars actually necessary? Thanks
[This message has been edited by 72step (edited May 14, 2002).]
72step is offline   Reply With Quote
Old 05-15-2002, 12:51 AM   #13
BubbaGreen
Post
If you go the early classic route, you will
get a 1-1/4" bar with energy suspension poly
bushings, the bar comes powdercoated as well.
I got one of these kits, mainly because it
included all I needed. It even came with
original GM brackets where for the frame to
sway bar mount goes.
Overall opinion: great...but expensive.
It comes with EVERYTHING...but that comes with a price. I am happy with mine and it
improved the handling tremendously, but my
truck didnt have a sway bar to begin with.
How much of a difference between 1-1/16 and
1-1/4"....guess I will never know!
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 05-15-2002, 03:23 AM   #14
The Blue Pig
Thread Wizard Since 2002
Post
Hey, that is why I logged on tonight, I was going to post the question if anyone had a rear sway bar, where they got it, how they mounted it, and if it made a noticeable difference. Also, if you just have like 2 inch lowering springs, do you need to get the sway bar relocator thing from early classics?
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
Old 05-15-2002, 11:11 AM   #15
j-dogg
Post
I got a 1-1/4 inch sway bar from an '84 dually. There were a couple other duallies in that junkyard with that same size swaybar, so you might want to keep an eye open for a dually if you want that size.
j-dogg is offline   Reply With Quote
