Old 03-02-2009, 12:11 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
how to tell diff. between thin and thick wall square tubing..
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
gonna do that^^ and have a piece of 2" square tubing...not sure if its thin wall or thick wall how do i determine this.....
thanks, and try'n be quick lol i'll go measure it rite now..
John
1999 Toyota Tacoma 4x4
Old 03-02-2009, 12:36 PM   #2
oldblue1968chevy
Re: how to tell diff. between thin and thick wall square tubing..
crap, turns out the biggest stuff ive got is only 1.5".......guess tomorow when i go to school i'll stop by the metalyard see what i can get...till then this project is postponed...thanks anyway
John
Old 03-02-2009, 01:03 PM   #3
cdowns
cdowns's Avatar
easiest way i know to tell if tubing is thick or thin wall is to look at the end crossection of it and see if its thick or thin//or measure the thickness with a micrometer
Old 03-02-2009, 01:18 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
What he said.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-02-2009, 01:48 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
imo thick = >.120"
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-03-2009, 01:06 PM   #6
MickMc
MickMc's Avatar
The easy well to tell is looking at the corners of the tubing.
Very sharp corners will be thin wall.
Rounded corners wil be thick wall.
Mick
MickMc is offline   Reply With Quote
Old 03-03-2009, 04:18 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The tubing I used when I wrote that article was 250 thou. I used it because it was available and overkill.
I kind of agree with the guy above though, as long as it's .125 or thicker, that's pretty thick. BTW 125 tho is 1/8 of a inch.
Old 03-03-2009, 08:41 PM   #8
oldblue1968chevy
hey tx firefighter, i used 2.5" thick wall tubing, got 8.5 lbs of it for 1 dollar lol
anyhow, where should i look tomroorw for someplace to get my u bolts, and will the 24" ubolt be eenough for for the added .5"
THANKS and i need help tryin to find where to get ubolts lol
John
Old 03-04-2009, 12:01 AM   #9
OARNGESI
OARNGESI's Avatar
have you thought about just buying a set http://store.gaugemagazine.com/loweringblocks.aspx
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-04-2009, 01:19 AM   #10
thirdstreettito
Resident of Here
He'll save some money doing it himself if he can get cheap u-bolts.
~Bradley~
Miss having a truck
Old 03-04-2009, 01:51 AM   #11
LuckyHenriksen
LuckyHenriksen's Avatar
Ya 35 bucks is alot to spend, especially when you can usually find the tubing somewhere for cheap or free
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 03-04-2009, 02:03 AM   #12
Skirkpat
Skirkpat's Avatar
The U-Bolts I priced were 28.00 + By the time you break a drill bit, etc. , that kit is close to the same price, I like to do this stuff, but 35.00 seems pretty cheap.
Skirkpat is offline   Reply With Quote
Old 03-04-2009, 07:17 AM   #13
Tx Firefighter
You can't use the lowering blocks in that link. Those are for leaf spring trucks. Our coil spring trucks use a much different setup.
Old 03-04-2009, 10:55 AM   #14
oldblue1968chevy
1 dollar for the 2.5" tubing 8.5 lbs for a dollar lol
halfs the fun makin it yourself
John
