Old 03-02-2009, 02:20 PM   #1
wHATANERD
wHATANERD's Avatar
Front Pillar Patch
This weekend I removed the hood and fenders on my 69 C/10 longbed. and found that the front door pillar on the drivers side is in really bad shape. I've been looking throught the the vendors websites, and my stack of catalogs at patch panels, and can only find what appear to be a piece that cover the damage, and don't replace it. I've attached a photo of the damage that I found, and what the patches that I'm finding look like. Has anyone had any luck with these patches? Are there any other type patch panels that replace the bad section? Any suggestion will be greatly appreciated. Thanks
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 03-02-2009, 04:15 PM   #2
tim21391
tim21391's Avatar
Re: Front Pillar Patch
thats what 88jrfan (daren) and i had to use on our trucks.. we also replaced the kick panel i think i would replace it on yours too.. its where you have painted silicone on your picture next to pillar... i got mine from wes at classicheartbeat.com its worth the money....
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-02-2009, 04:16 PM   #3
tim21391
tim21391's Avatar
kick panel and footwell patch = same thing
Old 03-02-2009, 06:26 PM   #4
craig24671
craig24671's Avatar
Hey! That is a weld in patch panel, I have used these on my truck. IMO looks like someone in the past done a slapstick job tryin' to repair that. But the panel you have posted is a weld in panel, hope this helps you out. I just cut mine off below the hinge and replaced it.
craig24671 is offline   Reply With Quote
Old 03-02-2009, 08:03 PM   #5
wHATANERD
wHATANERD's Avatar
Thank for the info craig, the raised part on the patch that looks like it goes over those two bottom bolt heads is what was confusing me. Does anyone have a photo of one of these patches installed? Thanks
Old 03-02-2009, 08:18 PM   #6
Kayotic
Kayotic's Avatar
I think you are looking at it wrong.
Looks like it just may be the angle throwing you off.
I always assumed they were exact replacements. Well exact in the fact you will have to drill the holes and trim to fit...
Very common here, I am sure there will be pics posted soon or try the search feature above.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 03-02-2009, 08:27 PM   #7
john
member #16
john's Avatar
Rokcrln has a good how to in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=271066
john is offline   Reply With Quote
Old 03-02-2009, 10:04 PM   #8
tim21391
tim21391's Avatar
just make sure on the old pillar there is a little bracket type thing that has the same big hole as the biller and a thing that has two holes in it.. you weld that on the back then drill the holes then you can put a bolt through it to line it up..... here is a board member that has helped me do my truck.. i dont have pics of mine on here yet but he did the same thing as what my truck needed.... hope daren doesnt mind me putting his build on here..
http://67-72chevytrucks.com/vboard/s...d.php?t=318227
Old 03-02-2009, 10:23 PM   #9
blakeaz33
blakeaz33's Avatar
I used that same piece and had good results with it
blakeaz33 is offline   Reply With Quote
Old 03-02-2009, 10:53 PM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
^^^^^ ditto!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-03-2009, 10:19 AM   #11
wHATANERD
wHATANERD's Avatar
Thanks for the great links and info. This board is great. Hopefully someday I get to post some completed pictures.
Old 03-03-2009, 04:25 PM   #12
tim21391
tim21391's Avatar
good luck with the build hope you dont have a problem with i had with throwing a few tools around the shop
Old 03-03-2009, 05:03 PM   #13
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Out in the salty North & NorthEast - that's what's described as a "rust-free original" I'll bet !!!
68shortstep is offline   Reply With Quote
Old 03-03-2009, 05:20 PM   #14
Ram-Man
Ram-Man's Avatar
I just cut up the replacement part and used what I needed.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 03-03-2009, 10:52 PM   #15
tim21391
tim21391's Avatar
is that a complete floor?
