1987 c10 rear disc brakes
i was looking for anyone that has done it useing the stock front set up and had pics of it done. I was looking to do with without useing all the kits that are going to rape me of my money.
tryin to get laid
Re: 1987 c10 rear disc brakes
Probably not possible because the rotors house the bearings. But who knows.
6.0 powered square
You can get them off any fullsize gm car with 5x5 bolt that has discbrakes
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
what i meant was useing the stock caplipers and were i could find a backing plate that i could use to get them to fit.
I like that. It's not that expensive either.
I have car A.D.D.
Nice kit. And good pricing too.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
Low & Fast!
That kit works very well and easy to put on.
Location: Where I come from, it's cornbread and chicken...
tvblazer, did you have to end up putting a valve on it...I have hydroboost brakes because of the diesel and I'm wondering if it would be the same or not...?
Chuck. |
#10 | |
Low & Fast!
Chuck, I put fine tune SSBC adjustable one on, as you know your drums have to have 10 LB to work and your disce only need 2 LB. And it will work just fine on yours. You can also put in a residual valve from Wilwood that works good, they are very small.. Good luck, Trav
