Keep On Keepin' On
Moving gas tank to rear...
Moving gas tank to rear...Easiest way? Best way? Best filler spot? Anybody put it hidden behind pull down license plate?
Thanks for the suggestions Clint
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
Re: Moving gas tank to rear...
I put a RCI fuel cell between the frame rails. My filler is an aviation cap on the bed floor. I don't know if this will suit your needs but it works well for me. Good luck.
![]() ![]() 68 GMC SHORT STEP 35 CHEVY PICKUP A FEW BIKES SINNERS C.C. |
hey lumpy can you post a pic of the av cap? I want to do something similar
there's been many posts about this topic; here's a few recent posts...
http://67-72chevytrucks.com/vboard/s....php?p=3085225 http://67-72chevytrucks.com/vboard/s....php?p=3154200 and here's mine... ![]()
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
Sweet my threads in there lol
After I swap my front drums for disc brakes, I intend on moving my gas tank to the rear also. I still dont know where i'm going to put the door. The bed floor would be the easier way but i think it would be a hassle with the tailgate down. Thinking about useing late model door on outside/ side of bed but i was thinking of putting it behind the license plate, hidden. I guess i wont know till i start the project.
Could be wrong. Have heard that behind the license plate won't work. As the tank is too high for the spout. Unless you put your tank lower than the filler tube. Would be about 4 inches off the pavement??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Someone on here used a tank from a 1st Gen F body, and it worked well as far as I know. It looked sweet, and the filler was behind the license plate
I had an aluminum tank made, going to put a flush mount marine style filler in the wood floor or just a flip door to the cap on top of the tank...
I thought about the Summit RCI tank that they have...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 03-05-2009 at 10:21 PM. |
What are you guys using for the sending unit? I have been planning on doing this to my truck for the last seven years, but I don't drive it much.
I just hate the wasted space, that the stock gas tank takes up, behind the seats. I have a 100 gallon tank, previously used for diesel oil, that I can convert. I would need to mount it across the bed. I also picked up a 20 gallon aluminum tank that can sit across the front of the bed. The problem with these two tanks is, should I need to load up one of my bikes, the bike might have too much weight on the tailgate. As for gas tank filler, personally, I like the behind the taillight filler.... So cool.
'72 GMC custom camper 350/350 Last edited by spinning wheels; 03-06-2009 at 02:41 AM. |
you can find sending units for generic tanks at JC whitney or brothers for about $30. 90 OHM unit for the 67 and up trucks. SOme of the SUmmit tanks comes with one already.
That behind the light filler is cool, so is the marker light filler and stake hole filler.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 |
Best to just buy a kit like this and concentrate on where you want the filler cap to be.
http://www.brotherstrucks.com/prodin...number=GTPDS72 |
#14 |
i used a 69 camaro tank with the filler behind the liscense plate, works great, looks clean
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
#15 |
These are about $110 from Summit and come with the sender. I'm not sure about a fill spot yet but most likely a lift open spot in the bed. I just bent up some 1" flat for some straps and some 1" square across the top for upper support.
#16 |
Grandpa in the rustmobile...
ram man, so the tank in that pic up there is from summit for 110$?
comes with sending unit and mounting straps and is a bolt in installation besides the filler? what do you gotta do, extend the fuel lines, and make a filler? thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#17 |
The price is approx I bought it a year ago. It comes with the sender but the straps and upper supports I made. It is just a drag cell that they sell. Basically about the right size to fit right in.
#18 |
senior member
i bought the cpp aluminum tank and was overall pretty happy with it
69 GMC bagged |
#19 |
I was off a little on the price its $144 with the sender and $116 without.
Here is the linky http://store.summitracing.com/partde...5&autoview=sku |
#20 |
can you any more pictures of the tank? sender, spout?
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
#21 |
144 with sender and straps..didnt see anything about the straps on the site?
what're you gonna do for the extended lines? on a lwb could you order lines for a suburban that'd bolt up?
#22 |
Here is a pic of one that a friend built for my sons truck. pretty crappy pic but you get the idea. holds 17.2 gallons.
#23 |
is that aluminum
? nice
#24 |
oldblue1968chevy,
yes its aluminum. all tig welded with baffle & sump to control fuel slosh. dont remember right off what thickness it is though |
#25 |
1 more time. I made the straps and supports on the top. Why not just bend some new lines. You can buy straight ones from any parts store pretty cheap.
