Old 03-03-2009, 01:11 AM   #1
pitbull
Question driveline angles?
im currently in the middle of swapping out my stock 350 and 4 speed for a 454 and th350
im using the original motor mounts adn cross member and its a long bed 2wd 1971 c10
my question is what are correct driveline angles for this two piece drive line
with the engine and tranny in i got 9 degrees down at the tail shaft and 8.5 degrees up at the pinion with the suspention loaded, and i need to make sure i dont have any vibrations
thanks for any and all input
pitbull is offline   Reply With Quote
Old 03-04-2009, 02:23 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: driveline angles?
that will work if youre talking about the angle of the output shaft and the angle of the pinion.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
