Old 03-03-2009, 10:34 AM   #1
jasons
not enough hours in the day
jasons's Avatar
Soft top on E-Bay
Came across this on E-Bay. Item # 290299894767. NOS Kayline top. Makes me wish I would have bought an extra when I got mine a few years ago.
jasons is offline   Reply With Quote
Old 03-03-2009, 11:32 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Soft top on E-Bay
Pictures would be nice, but here's the LINKY.
Not too sure if the statement about Kayline being the original manufacturer of soft tops for Blazers or them being Factory is true, but still a rare find.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-03-2009, 12:56 PM   #3
lgdpt
lgdpt's Avatar
Is a grand in line for what this is worth? What did they cost back when you could buy one new?
lgdpt is offline   Reply With Quote
Old 03-03-2009, 01:10 PM   #4
70 Suburban
Rods
ive looked for it... no mention in the fsm or fasm of a factory soft top option
70 Suburban is offline   Reply With Quote
Old 03-03-2009, 01:11 PM   #5
70 Suburban
Rods
for me I think its out of line. you can go to a baot shop and have one made for that kinda cheez. and you wont have to drill in to your truck
Old 03-03-2009, 01:42 PM   #6
bouncytruck
SKINNY TIRES RULE!
I paid right around $700 for my STC Fastrac. I think at grand is a good deal. Everyone on the board who has gone to boat shops has come back with estimates around $3,000.
By the way, all the tops require you to drill into your truck. The Kayline snap tops have rails that run along the top of the bed sides with the snaps in them. You will have to drill holes in the header and in the tailgate, but I had to do that with my Fastrac too.
bouncytruck 1972 K5
Old 03-03-2009, 01:52 PM   #7
70 Suburban
Rods
When i did the plans for mind I made a bolt in panel for the header . as for the tailgate I ll do mind the way a jeep does. that way I dont have to drill into it..
Old 03-03-2009, 02:03 PM   #8
bouncytruck
SKINNY TIRES RULE!
It always seemed like there was a way around it, but all the production tops I've seen (Kayline, Bestop, STC) require a series of holes drilled into the header and tailgate. The Kayline and STC also require at least one hole drilled in the top of the B pillar for the frame over the doors. Again, it seems like they could have put a mounting point into the bracket that bolts to the bed rails.
I would think the hardware is the expensive part. You would basically have to re-engineer the pivot points so the top will fold down behind the rear seat, bend the tubes and create all the brackets. I'm not an engineer, so this task seems overwhelming to me. I'm sure if you can draw up accurate plans, you could probably sell them for others to get tops made (since it appears actually making the tops isn't profitable.)
bouncytruck 1972 K5
Old 03-03-2009, 02:08 PM   #9
70 Suburban
Rods
ill see if i have pics of mine. I used angle aluminum. I bent the bows out of conduit for test fit. I made hinges for the arches of ther doors so it would seal somwhat. If you have sun visers then you will have a bolt right at the edge of the door and apiller.The only problem I had was with the forward bow hitting my roll bar.I used my set ua as a bimminy
Old 03-03-2009, 02:16 PM   #10
70 Suburban
Rods
i may do that. My jeep used a square tube that locked into notches on the sides of the tailgate. the top snapped onto that. I dont like drilling into the truck. I will be making my soft top as soon as I replace the lower a pillers and front cab mount. I robbed the hydrolic set up from a mustang in hopes to use it to make an automatic top. however again the roll bar is in the way unless I can make somthing like an extended cab soft top.
Old 03-03-2009, 04:26 PM   #11
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I put a tail gate protector on mine and didnt drill any holes in my gate.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-03-2009, 06:15 PM   #12
70 Suburban
Rods
I LIKE THAT BUT i DONT WANT TO RIP A SNAP OUT TRUCK TO UNSNAP IT TO OPEN THE TAILGATE
Old 03-13-2009, 09:44 PM   #13
mudman316
mudman316's Avatar
it went for over 1700 dollars. anyone here get it? it had bars and all the hardware.
BE NICE IT PAYS IN THE END.
mudman316 is offline   Reply With Quote
Old 03-14-2009, 05:09 PM   #14
glimmertwin01
glimmertwin01's Avatar
that is CRAZY !!
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 03-14-2009, 05:24 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-14-2009, 06:08 PM   #16
4bynut
4bynut's Avatar
There is one on CK5 for $500 and no ones has even asked about it.
http://coloradok5.com/forums/showthread.php?t=249985
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
