Old 12-15-2002, 06:03 PM   #1
halfwaythere
Anyone with engine knowledge help me out!!!!
I have a oil leak beteen the timing chain cover and the oil pan on my 72. is there any way to fix it without taking off the water pump, timing chain cover and oil pan.
Anything would help!!!!!!!1
everybody just seems jealous!!!
halfwaythere is offline   Reply With Quote
Old 12-15-2002, 06:07 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
I assume this is probably the crank seal that's leaking. You're right, pull the timing gear cover to replace the seal and put a redi-sleeve on the crank.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 12-15-2002, 06:11 PM   #3
halfwaythere
I dont think it is the seal because i did replace it. the leak is where the oil pan cups the timing chain cover. there is a U shaped gasket in there but in order to replace it do I have to jerk the oil pan???
Old 12-15-2002, 06:35 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
You might as well pull the pan, and put in a Fel Pro 1 piece oil pan gasket. You can get them at most any auto parts store. Then you won't have to invest in another pan gasket...ever. They're reusable if you'd ever have to pull the pan again, and they come with all new hardware. That's just my recommendation though, I've never seen a cork pan gasket with those rubber ends seal as easily as the Fel Pro 1 piece.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 12-15-2002, 08:39 PM   #5
Sierra
I second 68 Stepside's recommendation of the Fel-Pro gasket. My truck's timing cover gasket (on GM crate engine) is dripping oil on the garage floor as I write this! I've used the Fel-Pro one piece gasket on a couple of other engines, without problems. I just need to get my ducks in a row and get the dirty business done.
Sierra is offline   Reply With Quote
Old 12-15-2002, 09:03 PM   #6
Southpa
Southpa's Avatar
I replaced that very gasket ( U-shaped one) many years ago. Had to pull the fan, water pump, harmonic balancer and timing chain cover and just unbolt oil pan very carefully w/ out messing up the cork. Then work the gasket in along with silicon gasket sealer. 7 years and still holding. I'm kicking myself now, it was a perfect opportunity to replace the timing chain and gear, but money was an issue at the time.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
