turnin wrenches
LED tailights and third brake light
has anyone here ever used them in place of a factory light? and if so how hard were they to install? i have been thinking about using them for the cleaner appearance, as well as installing one ine the back of the cab either above the window or below.
any info fellas?
"three can keep a secret if two are dead" -unknown hell's angel- D.M.C. -FF- 68 SWB full frame off (project ol skool) 2000 s-10 formally bagged but now my daily driver... |
Seņor Member
For the non-stock taillights...
![]() ![]() Kenneth
turnin wrenches
those look nice.how hard were they to install?? i have a fleetside, and was thinking about 2 seperate bars, one simply for brakes and another for brakes and blinkers.........then the third brake light above or below the window. more than likely below unless i go through with the plan to install a power window from a k5 blazer
#4 | |
Seņor Member
![]() I'm contemplating a third brake light above the window done the same way but I'm concerned with how I will service the unit should I ever need to. Kenneth
turnin wrenches
that is my concern as well, plus my truck doesn't have the headliner in it either, so i would have to fab some sort of cover panel to hide it inside the cab, that i don't think is a big deal however. as far as servicing of the unti, i had thought about using something similar to newer panel fasteners, like you find in door panels and such on late model vehicles, the ones that just puch into the hole and lock themselves, that way if the unit ever needed to be reaired or replaced it would be a simple matter of pulling the cover off to get to the lights............it is a thought???
![]() Join Date: Aug 2001
http://community.webshots.com/image3...FrLqzoL_ph.jpg
HERES A PIC OF ONE I MADE OUT OF A CARGO LIGHT. OH WELL .. THAT DOESN'T SEEM TO WORK, BUT IF YOU CLICK ON THE WEB ADDRESS IN MY SIGNATURE IT SHOULD TAKE YOU THERE. ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 12-15-2002 at 11:49 PM. |
its all about the +6 inches
Cargo light is easy. Just go to radio shack and get some small red lights or LEDs, drill some holes and wire them up to the brake pedal. You can even retain the white light function unlike the one offered in the aftermarket.
And then with the lights out...
HEY ANDY .. DO YOU STILL NEED A LENSE FOR YOUR CARGO LIGHT??
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
actually I do, but with the fundage so low, it is rather low on my list. Since the one ton isn't cut for the cargo light (yet) it isn't a pressing issue.
turnin wrenches
even though that does look sweet, i am going for the shaved look on the truck....but that is something to keep in mind!! thanx
If going for a shaved look, I wouldn't bother with a 3rd brake light then, all it will do is clutter the sheetmetal.
#13 |
ANDY --- EMAIL ME WITH YOUR ADDRESS, & I'LL MAIL YOU ONE FOR CHRISTMAS (DON'T WORRY, YOU DON'T HAVE TO GET ME ANYTHING. ) LOL FK9U812@AOL.COM
#14 |
damn...thnks man. You have mail
