03-03-2009, 06:12 PM | #1 |
my interior is done but the back seat???
Does it bolt into the floor or am i suppose to get under there and hold a wrench on a nut? is the floor threaded? the interior guys couldnt get it back in very well so I didnt get to see how they took it out? they look like pointed bolts so i am leading torwards the floor being threaded but any help woulld be great.
Also I got a stock console. same question are there holes already there and do i need specific bolts or does it just get screwed to the floor? Thanks guys |
03-03-2009, 06:32 PM | #2 |
Re: my interior is done but the back seat???
Their should be a a metal plate under the bed with 4 nuts welded to it for the 4 back bolts about 4 feet long the metal plate is held up with 2 screws from the top. Their should be 2 nuts welded to the bottom of the bed for the 2 hold down brackets in the front.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 Last edited by Gary 70 Jimmy; 03-03-2009 at 06:33 PM. |
03-03-2009, 06:39 PM | #3 |
thanks
03-03-2009, 08:07 PM | #4 |
well i shoulda figured. IT AINT THERE!!! and of course the interior guys say it wasnt there when they took it ou . damn i hate when this happens does anyone sell it online?
03-03-2009, 09:55 PM | #5 |
I mite have one.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
03-03-2009, 10:31 PM | #6 |
let me know. thanks alot
03-03-2009, 10:36 PM | #7 |
SKINNY TIRES RULE!
If you're truck didn't come with a rear seat from the factory, it may not have the threaded inserts & support for a rear seat. Here's a pick of the rear brackets. Some have 4 across the back with the seat belts bolted to them, some only have two with the inboard mounted seat belts bolted directly to the floor. I don't have any pics of the front brackets, but there were some for sale on the parts board the other day.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-03-2009, 10:54 PM | #8 |
yes i have the four brackets across the rear and the two fronts. i also found something i thihnk will work for the front i can take a picture tommoroow
03-03-2009, 10:58 PM | #9 |
SKINNY TIRES RULE!
If I recall correctly, the console is held down with screws just into the sheet metal. I believe there are 4 screws total and two of them screw into the "ridge" in the floor plan.
03-03-2009, 11:06 PM | #10 |
SKINNY TIRES RULE!
Here are the bracket that hold the front legs of the rear seat to the floor.
http://67-72chevytrucks.com/vboard/s...d.php?t=331606 The threaded holes for the seat belt mounts are a different size than the threaded holes for the outside brackets. The seat belt mounts also use a special bolt so the belt mounts can pivot.
03-04-2009, 09:42 AM | #11 |
thanks mt main concern is the rear
03-04-2009, 12:41 PM | #12 |
Pull up the carpet/mat... mine had die cut plugs (sheet metal) over the holes. I have to assume that my back seat was never coreectly installed. The pieces pull up, cleaned the undercoating out of them and cleaned the threads with a tap. I suspect all tubs are stamped and prepped for a back seat.
03-04-2009, 06:24 PM | #13 |
mine has teh holes already there I guess I can just make a new one huh? Anyone here got the specs or one for sale?
03-04-2009, 08:50 PM | #14 |
SKINNY TIRES RULE!
This is the only picture I have that shows the mounting points. I'm not sure where I got this picture.
03-05-2009, 01:09 AM | #15 | |
Sorry for jumping in this thread, but was just curious to these mounting questions as well. Thanks. Last edited by JWPOORE; 03-05-2009 at 01:10 AM. |
03-05-2009, 07:02 AM | #16 |
The LuvShack Garage
PM sent
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-05-2009, 09:00 AM | #17 |
When I put my rear floor in my jimmy the holes in the new floor were in a differant spots so I couldnt use the metal plate that was on the floor of my jimmy I had to use the one that came with the new floor and move the brackets on the seat to line up with the new floor. I dont think my extra one will line up with yours unless you drill new holes and weld new nuts on it.
03-05-2009, 05:39 PM | #18 |
The LuvShack Garage
Sorry, all I had on me was my Blackberry.
This is the EXTRA piece that I have.
03-05-2009, 05:43 PM | #19 |
looks right to me man. i am in california 94062 . let me know
03-05-2009, 06:40 PM | #20 |
The LuvShack Garage
I'll check on shipping cost Monday and then PM you a quote.
03-05-2009, 07:05 PM | #21 |
how heavy do you think it is?
