03-03-2009, 06:43 PM | #1 |
Junior Member
Aluminum Flywheel? + Chassis Pics Inside.
Just wondering if theres a definite advantage to going with a lightweight aluminum flywheel if its to be used on the street (other than the obvious of course). I know the RPMs are supposed to drop WAAY faster, just wondering if its worth it. Anybody running one behind your small block? I'm at the point in my build where Im about to start puttin the drivetrain together and puttin it on the chassis...........thought to myself,......hmmmm Aluminum flywheel?? hmmph.
03-03-2009, 06:51 PM | #2 |
Re: Aluminum Flywheel? + Chassis Pics Inside.
I don't have an answer to your flywheel question but your project looks great. What kind of fuel cell are you using and are those later model upper and lower control arms on the front?
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
03-03-2009, 09:38 PM | #3 |
I ran a aluminum flywheel once upon a time in one of these trucks. I used a new then centerforce clutch and m22 with a 350 and tunnel ram/solid lifter .570 crane came. The flywheel will definitely let the rpms come up but in a heavy truck the heavier flywheel will workout better in the end. Motor would RPM up quicky but come down just as quick. From past experience you don't want to do it, spend the money on something else.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
03-03-2009, 10:11 PM | #4 |
Junior Member
Yeah, they are uppers and lowers from a 73-87. And the fuel cell is a "Jegs" cell from them. I built the frame that holds it out of 2x2 3/16" Angle Iron.
