Old 03-03-2009, 08:25 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Alternator Alignment for pseigmund
Here is my truck which I have not touched...not sure anyone has. I know it has a brand new starter so this might be a replacement alternator as well. I did not check to see if it still had the voltage regulator.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-03-2009, 11:07 PM   #2
stllookn
stllookn's Avatar
Re: Alternator Alignment for pseigmund
ttt
Old 03-04-2009, 12:37 PM   #3
pseigmund
Thanks for the pictures and the information. I will take a look when I get home tonight and see if I can figure out what is going on.
pseigmund is offline   Reply With Quote
Old 03-04-2009, 05:22 PM   #4
Bruce88
Bruce88's Avatar
From your pictures it looks like your ALT pulley is aft and needs to be moved forward.
It could be as simple as a washer in the wrong place (see attached pic)
You would be surprised as to how many v belt pulleys are out of alignment, normally it’s a small amount even from the factory. Throw in replacing water pumps and alternators it can be visibly noticeable (not all parts are made exactly the same). If you want to fine tune your v belt pulley alignment the technique/concept to figuring out how much shimming or movements of parts are required, I show how in this “How To” http://67-72chevytrucks.com/vboard/s...d.php?t=318240 concept will work on 6 cylinders.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 03-04-2009, 05:41 PM   #5
stllookn
stllookn's Avatar
Mine looks like the illustration you posted and is aligned perfectly...the picture I took for pseigmund is a little off.
Old 03-04-2009, 06:26 PM   #6
Bruce88
Bruce88's Avatar
My apologies for my misunderstanding of why the pictures where posted.
If pseigmund is having alternator alignment problems what I posted might help him out. Because I don’t know the whole story I might have supplied input that was not needed or sought sorry.
Old 03-04-2009, 07:08 PM   #7
Wrenchbender Ret
That is a 292 engine. It takes a different pulley then the others. Often people buy a reman alt. & dont change the pulleys. The 292 pulley has a space between the alt. fan & pulley groove. The lower bracket is different from a 250 also but I think you are ok there.
Wrenchbender Ret is offline   Reply With Quote
Old 03-04-2009, 09:15 PM   #8
factorystock
factorystock's Avatar
The pulleys are different on some engines. This is a 65 292 with the deeper pulley, yes the 292 was green in 65. But there are also 2 styles of alternator brackets that control the alignment too.
factorystock is offline   Reply With Quote
Old 03-04-2009, 09:33 PM   #9
rockc
Bruce 88 that is a great diagram and i can sure use it.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 03-06-2009, 03:12 PM   #10
pseigmund
Bruce88,
Thank you for the diagram, very helpful. I haven't had a chance to figure out what is wrong but will let you know when I find out. Good information on the different alt pulleys for 6 cylinders. Thanks guys, Pete
