03-03-2009, 09:49 PM | #1 |
hei help
i have a factory hei from the 80's i was wondering if i could use this for now until i can afford a newer one,my question is how can i wire it in to my 67's existing harness and it has a four pin plug harness?
03-03-2009, 10:42 PM | #2 |
Re: hei help
Yes it will work fine. The only wire you need to hook to it is a 12v from the ignition to the BAT terminal. If you have a tach that lead will hook up to the TACH terminal opposite the BAT terminal.
Take a look at this website for a little more info. http://www.chevelles.com/techref/ftecref5.html
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
03-04-2009, 05:33 PM | #3 |
Re: hei help
If it has the centrifical & vacuum advance systems it will work fine. If not you will loose a lot of power & fuel mileage.
03-04-2009, 05:45 PM | #4 |
Re: hei help
are these HEI tach signals safe for our stock tachs? i'm hesitant to hook one up...
03-04-2009, 05:50 PM | #5 |
its all about the +6 inches
Re: hei help
yes, it's fine.
03-04-2009, 09:46 PM | #6 |
Re: hei help
Just make sure you get 12 volts to the HEI.
I learned the expensive way, that the stock hot wire is a low voltage wire. I fried a new MSD module, not to mention a tow ride home. Funny thing is, on my '70 camaro Z28, I dropped an HEI in and hooked up the tach and everything worked just great. But my tach won't work with the stock distributor with points setup.
'72 GMC custom camper 350/350 |
