![]() Join Date: Jul 2007
67-68 to 73-87???
has anyone took a 67-68 body and put it on a 73-87 frame? if so, how?
Re: 67-68 to 73-87???
Not that I have heard of, and was just thinking the same thing today. Dopping a 68 swb onto a 77 swb. I suppose anything can be done.
Resident of Here
It has been done, but it is VERY hard to do.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
![]() Join Date: Feb 2001
4x4's are doable and pretty easy.
I see it done on 4wd frames.I don`t know why anyone would want to do it with a 2wd.The frames have some differences,but are basically the same.I don`t see any advantage.You`ll lose the coil suspension.I know the cab needs raised 2" for the bed to line up.So,4wd swaps are always higher than stock.The frame is longer in front,too.I`m not sure how you`d do the bumper.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-04-2009 at 08:31 AM. |
#6 | |
![]() Join Date: Dec 2008
its all about the +6 inches
reposition the rear axle forward to make it back to the correct wheelbase, custom lift kit, probably fab up body mounts here and there.
On a 2 wheel drive it would look retarded. A 67 - 72 frame is flat, the 73 to date frames are not flat, that's why you need the custom lift kit. |
