Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-04-2009, 09:48 AM   #1
rookierodbuilder
rookierodbuilder's Avatar
performance cam questions
Is there a company that makes camshafts for 4.3's that are compatible with the efi and the valve guides of a vortec head? Comp makes a cam that I am interested in but it has .500" lift with the stock rocker arm ratio and Im not sure if my heads can handle that kind of lift.
rookierodbuilder is offline   Reply With Quote
Old 03-04-2009, 01:02 PM   #2
Damien
Damien's Avatar
Re: performance cam questions
I think if you upgrade to the recomended springs you should be ok. Comp says you need to have adjustable valve train too, which means changing your studs. ARP makes screw in studs for the 4.3.
I would call Comp's tech line and find out what they recommend. Those guys are the experts.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-04-2009, 01:03 PM   #3
Myself
Crane makes cams for the 4.3, and Edelbrock does also. You can try GM Performance Parts too.
Myself is offline   Reply With Quote
Old 03-04-2009, 01:19 PM   #4
Damien
Damien's Avatar
I looked at Edelbrocks website just before I posted and did not find a cam for balance shaft engines. Crane Cams has shut down. I'm sure the cams will be available for a little while yet, but I don't think you will be getting any tech support from them.
I just searched GM performance parts and nothing came up.
