Old 03-04-2009, 02:30 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
steering wheel help
ok i got my new billet kit in the mail today i got the hazard part put on but to put the turn signal part on i think i have to take the steering wheel off but i dont see how i have the big nut in the center off but its still wont budge can some one help
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 03-04-2009, 02:45 PM   #2
JohnC
JohnC's Avatar
Re: steering wheel help
You need a steering wheel puller. The big nut kind of presses the steering wheel onto the splined shaft. They are really inexpensive at any parts store or hardware store. I have them at my hardware store for $6.99.
JohnC is offline   Reply With Quote
Old 03-04-2009, 03:46 PM   #3
pokethesmot
is there a truck to taking the blinker lever off with out taking the steering wheel off
Old 03-04-2009, 05:45 PM   #4
JohnC
JohnC's Avatar
Not that I know of. If you have the signal lever with the windshield wiper controls on it that's about the easiest way. In fact you may have to take out the wheel lock plate that is below the steering wheel too. If so you may need another tool, which is also real cheap, or you can do it by pushing down on the plate and taking the keeper ring off the steering shaft. However for the hassle and cost of the tool, BUY THE TOOL! makes it so much easier. Once you get that off you will be able to see the signal switch and there is a little piece in there that works the high beam part of the switch. Sounds complicated, but once you get into it, it's really not.
Old 03-04-2009, 07:33 PM   #5
pokethesmot
mines just a metal pole that operates the turn signals
Old 03-04-2009, 08:04 PM   #6
84 400
Sb 400 club
84 400's Avatar
Autozone will rent u the puller for free. I have done it a million times on Saginaw columns and it only takes a few minutes. The hardest part is removing the damm C clip retaining thing that holds the locking plate on. But i think they make a tool to do it. I just use two screw drivers.
used to have a good link but can't find it no more.......
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-04-2009, 08:47 PM   #7
f.monroe
f.monroe's Avatar
Pull the steering wheel and then there should be a black plastic cover over the locking plate . The plate meay have to come off but I do not remember . The turn signal rod just has a screw holding it to the turn signal switch . You will needd a puller to remove the wheel . I have sen them come off by pulling real hard on the wheel and tapping the center stud with a hammer but it will result in a nosebleed or worse when it lets loose .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
