03-04-2009, 04:10 PM | #1 |
Carb gurus
I have a holly 4106 600cm carb,that continues to drip fuel in the bowl which,then leaks out at the gasket between the carb and manifold.There is a pic of the carb and it's the one on the left.How do I fix this problem?
If it ain't a chevy,I don't want it |
03-04-2009, 04:24 PM | #2 |
Project '67 454
Re: Carb gurus
4 things could cause that,
1 Fuel pressure in excess of 7 PSI 2 Float set too high 3 Defective needle and seat assembly or o ring 4 Trash in needle and seat assembly 5 Bad float inside carb. The float probably wouldn't be bad, I would expect it to be 1,2,3 or 4. Have you ever been inside the carb? |
03-04-2009, 04:28 PM | #3 |
Re: Carb gurus
Please note that only four things can cause this but five are listed. lol
03-04-2009, 04:44 PM | #4 |
Re: Carb gurus
I agree with MRH on the 5 things. Has the carb sat at all? If so it needs rebuilt. Not sure why but holleys do not like to be shelved for any amount of time. Do you have a PAPER filter? Not one of those clear glass filters with the plastic screen. Those will destroy a holley quick fast and in a hurry. Also how is your float set? With the truck pretty level you should be able to pull the sight plug and bump the truck and have just a dribble of fuel come out. Well theres my .03 or .04 cents anyways. hope it helps.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-04-2009, 09:21 PM | #5 |
Re: Carb gurus
Thanks guys,the carb is new,that all that I know about carbs.I know that my gas gauge is not right,would that also be a sign?And the filter is the black,like the material is like a thin piece of cardboard.
If it ain't a chevy,I don't want it Last edited by greygoose; 03-04-2009 at 09:24 PM. |
03-04-2009, 10:01 PM | #6 |
Re: Carb gurus
my 4160 holley does the same thing sometimes. I have called holley and taken it apart and never found the problem. most of the time if you tap on the bowl with a screwdriver it will go away. one time i had to drain the bowl by loosening the bolts to make it go away.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
03-05-2009, 07:43 AM | #7 |
Re: Carb gurus
I used to have a small business modifying Holley's for oddball applications like inline 6's.Flooding was always the things mentioned above.
Doing a SBC recently and having some flooding issues with an Edelbrock carb I got to checking fuel pressure.I tried two fuel pumps,one a new Delco pump and a Airtex rebuilt.The Delco had in excess of 9 psi and the Airtex about 7 psi on a warmed up running engine.When the engine was shut off the pressure rose a little higher for a short time before it dropped off.A simple Holley fuel pressure regulator and wrapping the fuel line with an insulating material solved the problem for me.But if you're having excessive fuel pressure from heat soak after shutting down then a regulator with a return might be required. And make sure the fuel line isn't routed closly to the hot engine and insulate it if necessary. |
03-05-2009, 10:18 AM | #8 |
Re: Carb gurus
Thanks guys,would a regulator from any part store do the job?
03-05-2009, 11:26 AM | #9 |
Project '67 454
Re: Carb gurus
You need a regulator that will adjust fuel pressure from @4-9psi. If you don't already have one I would first buy a Combination vacum/pressure gauge available at most parts stores and check the pressure to see if that is the problem. You can also use that gauge to set the air/fuel mixture on the carb.
03-07-2009, 07:38 PM | #10 |
Re: Carb gurus
Ok guys I got the pressure regulator from autozone,and it worked fine,no leak.But today when I started it up it ran ruff and then it died,so I took off the fuel out side and turned it over but it wasn't getting any gas.So I took it back off and it run good,but now I have the leak again.By the way the fuel pressure regulator was a round looking thing with a dial knob on it and it went up to five psi,I think it was made by spectrum or something like that,it was 26 bucks,the guy at the store went over by the dress-up kit stuff and got it.So,is it just a cheap one or is there something else wrong with it?
03-07-2009, 11:01 PM | #11 |
Re: Carb gurus
And another thing that you guys maybe able to help me out with.Normal driving is fine,but when I step on the peddle hard there is a hesitation before it kicks in,almost like it's goes silent or like a drop off or something.What is that and how do I fix it?
03-08-2009, 12:27 PM | #12 |
Re: Carb gurus
HELLO,different carb (edel 1406)but running that same regulator that works just fine.anything above 3.5 psi and mine does the same thing,leaks,runs like
crap etc. |
03-08-2009, 03:08 PM | #13 |
yes, i do
Re: Carb gurus
that's weird. my old 4160 never liked anything over 4.5 psi. as for the hesitation, it sounds like you have either too much advance or a lean condition. so you probably need one to two sizes richer on your jets. start with the next richer jet, and drive it. if you still get the hesitation, go to the next. my edelbrock had the same hesitation and i fixed it by richening the metering system(rods and jets).
03-19-2009, 09:11 PM | #14 | |
Re: Carb gurus
03-20-2009, 08:36 PM | #15 |
No No
Re: Carb gurus
To be honest I'd say the float level needs to come down on the back a tad. The cheap fuel pressure regulators work ok there not great. A return style regulator would be more ideal since instead of having the fuel pressure dead headed it routes the fuel back to the tank this makes electric pumps very happy and keeps mechnical pumps from weeping. This is the whole reason the 3 port return sytle pump was invented. but yeah Ive got my electric pump dead headed on my truck works real well for full on high rpm flow but driving on the street it can be picky.
EDIT: Just courious how much vacuum your engine is pulling? Ive seen cases where the engine is pulling soo much vacuum it will pull fuel from there just becasue the vaccum is very high. Slightly opening the rear throttle blades up solved this problem thats why on the back side I always flip the adjustment screw around so it can be adjusted from the top of the carb. A small adjustment there might also help with the bog if its a lean bog
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler Last edited by SSC's76; 03-20-2009 at 08:40 PM. Reason: I aint drunk enough to think ok! |
03-21-2009, 08:02 PM | #16 |
Fabricate till you "puke"
Re: Carb gurus
I dont know how new the carb is, but I have "fixed" the fuel drip problem by installing new bowl & metering block gaskets in a used Holley carb. most of the Holleys I have run will tollerate around 8psi on the pump, & not upset the needle(assuming it seals properly).....5.5 -6psi on a stock pump wont jack with them. The edelbrock carb is more sensative to fuel pressure(5-5.5 psi). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
