Old 03-04-2009, 05:28 PM   #1
see ten
WTB this ad
see ten's Avatar
Hidden hitch + Fuel cell guy tank???
OK fellers! I'm trying to find out if the Early Classic Enterprises hidden hitch and Fuel Cell guys tank are compatible. I've been PMing Mark (Fuel cell guy) about the details of his product and he has been extremely helpful! He was however unable to confirm 100% that his product would work in conjuction with a hidden hitch. So...What can you guys tell/show us?? I've been poking around with our search feature and found some iffy information. Some posts claimed that crossmembers would have to be removed to use the tank and an ECE crossmember or hidden hitch would have to be added to use the tank. Some other posts I saw stated that none of the crossmembers would have to be modified but made no mention of using a hidden hitch. So, Show us what you got! Tell us how you did it! Are you running an ECE hitch and a Fuel Cell guy tank? Speak up and be heard!
Thanks guys!
see ten is offline   Reply With Quote
Old 03-04-2009, 06:05 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Hidden hitch + Fuel cell guy tank???
Thanks guys!
Here's some pictures of the one installed in my CrewCab. I didn't have any issues.
Hart_Rod is offline   Reply With Quote
Old 03-04-2009, 06:08 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
cool glad you asked that, those 2 mods. are goin on my things to do list
John
1999 Toyota Tacoma 4x4
Old 03-04-2009, 06:16 PM   #4
see ten
WTB this ad
see ten's Avatar
Well....That answers that question doesn't it!! Did you weld the nuts on to the frame that hold it all together?
Thanks!
Old 03-04-2009, 06:31 PM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks!
I haven't yet. I will probably do something similar to my ECE tank setup. It had some bolts that were welded to a 1/8" steel plate that would quit spinning when it hit the tank or the frame.
Old 03-04-2009, 07:24 PM   #6
killer71
killer71's Avatar
check out the killer build up...it had that set up. don has detailed picts of the way he mounted the hitch and the tank including the welded nuts!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-04-2009, 07:26 PM   #7
1970SWB
1970SWB's Avatar
I'm actually wondering the same thing, but with the ECE hidden hitch & the poly replacement suburban tank in a swb.
1970SWB is offline   Reply With Quote
Old 03-04-2009, 07:31 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Get the ECE hidden hitch for the blazer/suburban
leddzepp is offline   Reply With Quote
Old 03-04-2009, 09:20 PM   #9
see ten
WTB this ad
see ten's Avatar
Any idea of what page of that monstrous build thread I should be looking for???
Edit: Found it!!
Old 03-05-2009, 12:17 AM   #10
68 short step
here is a little help/pics
it works no problem...only peice that needs to be modded/removed is the spare tire cross member.....also pending on the size of the tank you may need to move the rear most x-member back....
68 short step is offline   Reply With Quote
Old 03-05-2009, 12:22 AM   #11
Hart_Rod
Hart_Rod's Avatar
I forgot to mention, I used the ECE rear crossmember.
R/
Old 03-05-2009, 12:35 AM   #12
SactoJim
SactoJim's Avatar
Here's mine....
Receiver was non specific that I had laying around and just narrowed it a bit....fits perfectly right behind license plate.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-05-2009, 01:31 AM   #13
tekno62
send a link please
Edit: Found it!!
tekno62 is offline   Reply With Quote
Old 03-05-2009, 06:55 AM   #14
see ten
WTB this ad
see ten's Avatar
This link is to page 7 of his build...there is also some info on page 6.
http://www.67-72chevytrucks.com/vboa...=244448&page=7
It looks to me like the fuel cell comes without any mounting holes, correct? It also looks like you guys are using two of the holes for the hitch and then adding a couple more that are just for the tank. Am I in the ballpark?
Old 03-05-2009, 09:29 AM   #15
Hart_Rod
Hart_Rod's Avatar
That's correct.
Old 03-05-2009, 07:33 PM   #16
68 short step
yelp
Old 03-05-2009, 07:47 PM   #17
tekno62
where did you get the ECE fuel tank?
Old 03-05-2009, 08:52 PM   #18
see ten
WTB this ad
see ten's Avatar
I'm not sure but I think all of these tanks pictured are from board member/vendor "fuelcellguy" or http://www.aluminumfuelcell.com/ . The trailer hitch is from ECE which is Early Classic Enterprises or www.earlyclassic.com .
Old 03-05-2009, 09:54 PM   #19
Hart_Rod
Hart_Rod's Avatar
Here's some pictures of my ECE tank in my Suburban. Very nice product, but $$$$$$, .
Old 03-05-2009, 10:00 PM   #20
texanidiot25
Eat My Rust
texanidiot25's Avatar
Even adds a bit of protection around the tank, nice.
texanidiot25 is offline   Reply With Quote
