I miss this truck.
Carb opinions
Looking to upgrade from the factory rochester 2bbl on my stock 307already purchased stock 350 manifold ( I know, not the greatest, but we're woking with a VERY tight budget) Is a 600cfm 4 barrel too much carb for the stock motor and 350 intake?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Fabricate till you "puke"
500 cfm would be enough carb for the 307, but I dont think the 600 would hurt anything.......as long as its not a Holley DP. A o-1850 Holley (vac secondaries), or a 1406 Edelbrock should be fine. either carb would need an adaptor to run on a stock Q jet manifold(I would use a 4 hole adaptor). You could also use an old Q jet......they are 750 cfm, but the air door on the secondaries wont let it be overcarbed. Good luck.....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: Dec 1999
AS long as carb brand dont start with a H you will be fine! i had a 600 Edelbrock on a 305 and it ran great,but go9 for electric choke they are calibrated leaner,i even have a 600 and it runs better than the 750 on my 402.runs like a top,not lean or anything good freeway power,low end.A good working Qjet is a wonderful carb IF it works right,and the throttle bushings are good.
If you want a Holley though i believe i have quite a few 600s in a box,collecting dust and get baked in the hih temps so a regasketing and cleanup would be necessary.think theres some 1850s left,i usually take every one to swapmeets i know theres some 750,780s and a 850dp.
#5 | |
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I miss this truck.
Thanks for the input.
I miss this truck.
Rat, what are you asking for the best 600 ya got? Don't forget I'd have to ship it to KY.
