Old 03-04-2009, 11:25 PM   #1
Row
Brake booster quick question
Is the booster the same for drums and discs? My booster has a vacuum leak and needs to be replaced. Problem is, I wanna switch to front discs soon. So can I replace the booster and then switch to disc and be ok?
Row is offline   Reply With Quote
Old 03-04-2009, 11:29 PM   #2
Sammy
Re: Brake booster quick question
Yes same. Difference is valve on the side of the master cylinder.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-05-2009, 12:10 AM   #3
Row
tyvm
Old 03-05-2009, 12:42 AM   #4
SactoJim
SactoJim's Avatar
I concur.....I'm running 4 WDB with stock vacuum booster and Corvette style master cylinder.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-05-2009, 01:12 AM   #5
spinning wheels
spinning wheels's Avatar
Where is it leaking from? Do you hear a leak? Or are you loosing pedal pressure? There is a small seal between the master cylinder and the booster, it may just be leaking from there.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-05-2009, 01:18 AM   #6
ED67C20
I've been told on this forum that they were different. Something that has to do with the push rod going into the back of the master cyl. Huh, I guess I can just try it. ED67C20
ED67C20 is offline   Reply With Quote
Old 03-05-2009, 02:02 AM   #7
Scottshotrods
the bore size on the master
are diffrent
disc and disc 1 1/8 bore
disc and drum 1 inch bore
justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 03-05-2009, 09:27 AM   #8
Row
Spinning wheels: to be honest, I really don't know where it's leaking! I think it's the booster diaphram because my engine dies when I'm coming to a stop. Also, when I mash the brake pedal, it makes a swooshing sound.
Old 03-05-2009, 10:49 PM   #9
spinning wheels
When you remove the booster. A knowledgeable brake shop can bench test it for you. I thought I was given, (well I bought it), a bad booster. But when they bench tested it, it worked fine.
It was missing the seal, about a $1 part. The hard part was chasing down what part was bad, as I changed booster, master cylinder, proportioning valve and added speed bleeders.
Next time, I'll change one thing at a time
Also, check your valve going into the booster. That little white plastic thingy, (my technical term), were you hookup the vacuum line from the engine. On yeah, you are getting around 15 inches of vacuum to the booster, right? Big cams will kill your vacuum.
Old 03-06-2009, 12:56 AM   #10
Row
Soon as I remove it I'll have it tested. Thanx for all the input!!!
Old 03-07-2009, 05:59 PM   #11
ED67C20
Row, I have tested them before with one of those mityvac vacuum pumps. As long as it will pump vacuum and hold it you should be O.K. I have another car with a bad booster. It will be idling perfect until I press on the brake pedal. It makes a hissing sound then it causes a vacuum leak to the motor making a rough idle. ED67C20
