Old 03-24-2002, 04:16 PM   #1
bigjimzlll
bigjimzlll's Avatar
Post want to get it right this time......
OK my 67 long bed is going to get the new 355..LOL..I just want to be able to do burn outs at will...the comp..is 10.2 to 1 i have the bowl ported 186 heads..stealth intake,,1405 carb...th 350 ..2500 stall. and 3;73 gears..posi.. What cam will be best?..and will this combo be able to light em up????
67 lwb fleetside...first hotrod in 25 years...283..186 bowl ported heads..270h comp cam 600 1405...stealth intake..HEI..th350 with 2500 rpm stall..4:10 POSI
god I love to go fast
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-24-2002, 04:23 PM   #2
69 longhorn
Post
I would say that the comp 270h in your 283 would be a good grind to use in the 355.....2500 stall,& the rear gears should work out good.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
