![]() Join Date: Mar 2003
I have a 72' 3/4 and which way should the spare tire face under the truck with the carrier in place? Should front of the wheel be up or down towards the ground? Thank you.
425hp409
![]() Join Date: Oct 2008
As a general rule, the spares usually mounted with the outside down so you could get to the valve stem to check the air pressure and add air as needed with the tire mounted under the truck.
Charles |
