Old 03-05-2009, 01:18 PM   #1
otsenre
otsenre's Avatar
how to remove woodgrain insert on glovebox
getting ready to paint glovebox, thought woodgrain had clips or screws to hold it on there, I cant figure out how to remove, anyone know?Name:  IMG_0771.jpg
otsenre is offline   Reply With Quote
Old 03-05-2009, 01:56 PM   #2
cdowns
cdowns's Avatar
Re: how to remove woodgrain insert on glovebox
its a vinyl stickon decal non reuseable// sometimes a heat gun will help you peel off most of it in pieces then its just a matter of scraping the rest off with a scraper or razor blade then cleaning up the excess residue with laquer thinner
Old 03-05-2009, 01:57 PM   #3
R.L.
R.L.'s Avatar
I'm not sure but I think it glues on and if it does a heat gun will help get it off.
R.L. is offline   Reply With Quote
Old 03-05-2009, 01:58 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Cool...how do you get the Cheyenne badge off?
leddzepp is offline   Reply With Quote
Old 03-05-2009, 02:04 PM   #5
otsenre
otsenre's Avatar
I want to keep the woodgrain, I thought it was easyly removeable as were my door panels. Guess I will have to mask it off, Thanks guys
Old 03-05-2009, 03:17 PM   #6
sameyrasmea72
sameyrasmea72's Avatar
You want to remove the whole appliqué from the door, not the wood grain from the appliqué right? Take a butter knife of something real flat and gently work your way around the Cheyenne emb. It is held on with 3 barrel clips.
Then take the same butter knife of a putty knife and start on the aluminum appliqué working your way around and around being careful not to dent the aluminum from the back side. It is glued on there very good and this is the only way I know of to get it off.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-05-2009, 03:21 PM   #7
You`ll have to get behind the emblem and careully pry to find the mounting pins,it pushes in.Carefully pry off watching to pry at the pins.Just a little at a time at each pin.
Use a heat gun and carefully pry,again,on the applique.It`s glued on.
Old 03-05-2009, 03:26 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Great info guys!...tried to do this once, and stopped when I figured I was going to tear it all up in the process.
Old 03-05-2009, 06:57 PM   #9
cparman
sharp as a marble
like all have said above!! I removed the aluminum thingy that the woodgrain decal was applied to. It was held on with double sticky tape. I got one of those razor blade knives that will extend out and the blade is able to be broken off. A little laquer thinner to soften up the glue and the razor thingy, two or three beers, and WAALLLAA. Did not even bend the aluminum thingy.
cparman is offline   Reply With Quote
Old 03-05-2009, 10:46 PM   #10
otsenre
otsenre's Avatar
Thanks for the info you all, I am just going to mask it off and paint!This is for me, not for Mr Obama
Old 03-06-2009, 06:58 AM   #11
Not a bad idea.It`s kinda touch`n`go,so that`s safe.
Just a note:These have no vinyl and aren`t stickers.The woodgrain is photo etched directly onto the aluminum.The woodgrain bezels we can buy are mylar stickers and so is the glovebox door woodgrain,it`s not an applique.
Old 03-06-2009, 09:00 AM   #12
Curt's_72
Curt's_72's Avatar
Good information guys. I purchased the woodgrain cover for my glovebox, not knowing till after the fact that the trim ring isn't part of the decal. Doh! Now I'm searching for a complete glove box door to complete the look. I'll know now how to attempt to remove the entire assembly.
Curt's_72 is offline   Reply With Quote
Old 08-15-2023, 07:54 PM   #13
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I know this is a old thread but great information!
The blue tape I put down around the emblem seemed to catch some wood grain paint, which is a bummer. I used my plastic pry bars for the emblem & wood grain appliqué, they came up easily and in no time.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
