03-05-2009, 01:56 PM | #1 |
Sunburst C10!!!
headers
do you think these headers will fit on a 1964 c10 stock ride height
http://www.southernrods.com/categori...oduct-821.html
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 03-05-2009 at 01:57 PM. |
03-05-2009, 02:16 PM | #2 |
Resistance is Futile
Re: headers
No.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-05-2009, 02:19 PM | #3 |
SIR
Re: headers
you can buy "coated" headers brand name "flo-tec" from kragen,shucks,or auto zone,for much less,there good quality and work well.........
66long low fleet http://community.webshots.com/user/LVNR66 |
03-05-2009, 04:18 PM | #4 |
Sunburst C10!!!
Re: headers
Gage 1967 C10 Shortbed Stepside |
03-05-2009, 04:43 PM | #5 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
Re: headers
bb or sb?
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
03-05-2009, 04:44 PM | #6 |
Sunburst C10!!!
Re: headers
sb
03-05-2009, 11:06 PM | #7 |
Re: headers
I think the tubes drop down and would interfere with the cross member or motor mount saddle. It has nothing to do with ride hite. Most headers that work or are designed for trucks shoot the tubes back pretty far and then drop down. I didnt read any specs for them on your link, but if they are designed for even 73+ they mite work. If they are a general hot rod header I think there would be issues.
You ought to be able to get a header designed for your truck for substantially less $$, I would guess.
03-06-2009, 12:47 AM | #8 |
Re: headers
Its not a bad price for a quality built and quality coated header if they are indeed quality built. However, if the image is of the actual headers, there will be significant firewall clearance issues, Those couple of tubes swoop waaay back. I could be wrong, but thats my observation.
Hooker makes an 1 3/4" header for our trucks, I believe. Last edited by FreeRideYZ250; 03-06-2009 at 12:48 AM. |
03-06-2009, 01:06 AM | #9 |
60-66 Nut
Re: headers
A lot of what will determine whether or not if a given header will work for you is whether you have a manual trans or an auto. Reason being the clutch bellcrank position. Hedman makes headers specifically for the '63-'66's (actually I think they fit back to '55) which are part #60260 or the elite ones 69268. These will work with a manual trans, no question. But they are 1 1/2" primaries. I myself prefer to use the later model headers like the #69090's or the elite's #69890. They also make a 1 3/4 primary header #69080. However the later model headers may require modification to the bellcrank.
A whilr back another member found that a particular Hooker header which is for later model trucks will work with a manual trans. Do a search for posts by 64magoo.
03-06-2009, 01:07 AM | #10 |
Re: headers
Try Jegs on the web they have a header that I used 737-h8021 by patriot on a sb in a 64 c-10 paid 165.99 or look around they offer alot headers .
03-06-2009, 09:14 AM | #11 |
Sunburst C10!!!
Re: headers
its an automatic i have long tube 1 5/8 headers now but i want some coated ones
03-07-2009, 01:07 AM | #12 |
60-66 Nut
Re: headers
The Hedman #69890's would be the way I would go.....
03-07-2009, 11:12 AM | #13 |
Re: headers
the add says "tri-5" . usually anything tagged tri-5 has to do with 55-56-57 chevy passenger cars. not a whole lot of info in that add
hey.....smell my finger 64 nova wagon , 63 nova convertible |
03-07-2009, 01:00 PM | #14 |
Sunburst C10!!!
Re: headers
thanks to all of you i think i will go with what captainfab said the hedmans are coated and only $285
06-12-2009, 09:19 PM | #15 |
Sunburst C10!!!
Re: headers
anyone know i can find some 1 3/4 headers i like the hedmans but theyre not big enough
