Old 03-05-2009, 05:38 PM   #1
MonteSS454
MonteSS454's Avatar
Errr, I hate stripped bolts...
Ok the carriage bolts holding the bumper on, got to the last one and the square part stripped and now I can't get it to stay in place so I can break the nut loose. Any suggestions? Don't want to hurt the bumper any though.
MonteSS454 is offline   Reply With Quote
Old 03-05-2009, 05:44 PM   #2
lowriden58
lowriden58's Avatar
Re: Errr, I hate stripped bolts...
2 options, weld a nut on the face of the bolt or torch it off from behind
unless you can get some vise grips to grip the head???
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 03-05-2009, 06:07 PM   #3
Senator350
Senator350's Avatar
oh... you could do all sorts of things.
y weld a nut on the face when you can just weld a whole handle on there?
Or use a cut-off wheel to put a notch in the face for a flat ended lug wrench.
I wouldn't bring a torch near the bumper if it's chrome.
RN U OVR
Senator350 is offline   Reply With Quote
Old 03-05-2009, 06:08 PM   #4
cdowns
cdowns's Avatar
grind or cut the nut off or use nut splitter//its better to remove the complete assy with the braces and all from the frame to get it out on the ground to work on it
welding a nut on the face of the bolt is a waste of time since bumper bolts are covered with a stainless steel cap and the cap would need to be removed or the bolt would still probally turn with the cap on
Old 03-05-2009, 08:30 PM   #5
sjarrett71
sjarrett71's Avatar
I've used a nut splitter on bumper bolts a dozen times. Works real good.
sjarrett71 is offline   Reply With Quote
Old 03-05-2009, 09:26 PM   #6
MonteSS454
MonteSS454's Avatar
Ended up cutting it off, with minimal damage to the bumper. Didn't think of cutting flathead slot in it :P
