Old 03-05-2009, 06:03 PM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Accelerator petal quandary
I had planned on using a Lokar petal and linkage but after reading the directions you can get on line I believe I might do better with a stock set-up from a 70s/80s vehicle. Has anyone had experience with this kind of petal for their ride?
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 03-05-2009, 06:10 PM   #2
OrrieG
OrrieG's Avatar
Re: Accelerator petal quandary
I sold the assembly out of my 74 donor truck to a guy for a street rod. Push the pedal and the upper rod pulls a cable through the firewall to the carb linkage. I am using the stock 59 V8 linkage in mine. Why won't the Lokar work?
OrrieG is offline   Reply With Quote
Old 03-05-2009, 06:14 PM   #3
BIG CHEVY 3600
It would work but the directions showed some kind of hole in the floorboard etc. etc. It just looked much harder than it should. I've seen an OEM setup somewhere that looked real simple to install but don't remember where I saw it. Plus the Lokar must be made out of platinum. $$$
Abraham Lincoln
Old 03-05-2009, 09:28 PM   #4
renegade6
I used one out of a late 80s, early 90s van with a throttle cable from a same year truck.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
