Mech. fuel pump location
OK I'm about to go nuts here. I've looked all over the engine bay for the fuel pump and I just don't see it (It doesn't help that everything is covered in grease)
I've got a new one coming in tomorrow, but as of right now I can't even find it. Anyone have a picture of the stock location for the fuel pump in a 77 C10?
Blue - 77 Chevy Scottsdale |
Re: Mech. fuel pump location
if its a small block or big block v8 it's on the passenger side right in front of the exhaust manifold. it will have a hose going from it to the frame. or just follow the fuel line from the carb to it.
Not trying to be a jerk but if you dont know where the fuel pump is the fuel pump drive rod will probably have you pulling your hair out
1963 Nova Super Sport 454 4 speed 1991 Camaro 350 1980 Chevy Stepside Long Bed 4x4 402 Big Block |
I've been working on fuel injected systems with the pumps in-tank or near the tank for years. This is the first time working with an older vehicle/carb setup. Of course I'm not going to know where things are at right off the bat.
And if the drive rod gives me problems, I'll hit it with a hammer. It's always worked for me in the past.
Don't know if the hammer will help. Don't think the old saying "If all else fails get a bigger hammer" applies here.
newbie
I hope this helps.
![]() Last edited by dga93; 03-05-2009 at 09:27 PM. |
Thanks to you guys that offered help. Found it after taking off a few pounds of sludge
Happy to be here
![]() Join Date: Mar 2000
newbie
i had trouble with mine a few days ago... the rod that goes up and down was stuck. took a few to figure out how to get it back up to put the pump on.
That article should help you out, another thing i do is ill use a short length of old hacksaw blade to hold the rod up and slide the pump into it. Once you start screwing with it youll see what i mean
