It's alsways something.....
![]() Join Date: Nov 2008
Explorer diff into 67??
I have my 67 front changed to 5 lug with drop spindles and springs and I want to run discs on the rear as well. Looks like one possibility is the Ford Explorer rear, I found one locally for cheap. I am ordering custom wheels, so the lug pattern isnt a biggie. The ratio would either be 3:55 or 3:73 either OK for me
Has anyone successfully installed one of these in 67-72 that can comment on the installation and results? The foto below is courtesy of board member b00sted |
Happy to be here
![]() Join Date: Mar 2000
Re: Explorer diff into 67??
Just cut everything off that don't fit a GM and weld back on what does..
![]() Why not just redrill the axle's for 5x5 pattern?
The Explorer differential is 59 3/4" btween wheel mounting surfaces. Anyone have the measurement for the 67 stock diff?
Truck Junkie
![]() Join Date: Aug 2008
A true 67-68 should be 61 inches wide
why are the spring perches set the way they are?
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
X2. I was thinking that they were for the sway bar or something.
James
James |
Gearhead
Yea I would say sway bar too, you can barely make out the perches on the bottom of the axle just mout board of the vertical perches
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
