Homemade Bed Wood
Finally completed cutting ,sanding & finishing wood for the bed. Old Chevy Manuals Online & MAR-K both have all the information needed to make your own.
Re: Homemade Bed Wood
Very nice work. Not for sure on what kind of wood, cherry? What kind of finish did you use.? I used automotive clear coat on mine.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
I was told it's Mahoghany wood ,I used spar urethane for the finish. I happy with the way it all turned out , especially with what I got invested
Very nice.
nice i will do the same...
I would say that mahoghany is right. Did you finish all the way around the boards?
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 03-05-2009 at 09:59 PM. |
Yea ,they're sealed 360 degrees
Looks good I plan on doing the same I have some cherry left over from an old project
![]() i |
did you stain it first? just curious clear would react to the oil based stain.
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
http://67-72chevytrucks.com/vboard/s...d.php?t=323944
check this thread out for pictures of my bed that i made. p.s., no stain
