Old 03-06-2009, 01:26 AM   #1
tekno62
A/C compressor question
A/C compressor is froze up. I was wondering if theres an upgrade or if I should just go with the 1972 model. Im not in to the keep it original - but like to get one thats not a HP hog.
tekno62 is offline   Reply With Quote
Old 03-06-2009, 04:44 PM   #2
Wrenchbender Ret
Re: A/C compressor question
There are newer styles that are lighter in weight & take less power, but you would have to change brackets & all. The old original A-6 comp. are very rugged & used ones are plentiful & cheap. They are usually just as good as a reman. Be sure to flush the system before you replace it. The metal particles with damage the new one. Is the comp. its self froze up or is it just the clutch brg.? The clutch brg can be replace without pulling the comp. with a couple of special tools.
Wrenchbender Ret is offline   Reply With Quote
Old 03-06-2009, 04:51 PM   #3
tekno62
not sure whats wrong with it. the PO didnt have a belt on it and I cant spin it with my hand
Old 03-06-2009, 04:54 PM   #4
Wrenchbender Ret
Which part or parts dont turn ? the hub on the end or the pulley that the belt goes on.
