12-16-2002, 03:20 AM | #1 |
Intake manifold question
If I decide to use a q-jet on my new engine, I am thinking about using this intake manifold (GMPP cast iron high rise). What I am wondering is can you mount the coil for the divorced choke on it?
It looks like it, but I am not really sure.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
12-16-2002, 08:11 AM | #2 |
If you have the right style, it will bolt up to the manifold. The style you need has an aluminum base and the coil is attached on top of the base. Heat transfer is through the aluminum to warm the coil.
Jim |
