My truck project has ended..
After the help of all of yall on here and Houston54 I have worked out a deal wiith the P.O. to buy the truck back as it was sold under the assumption of it being clipped with a camaro fornt end.. I will not go into details about all of what has transpired but he knew I was buying the truck to lay the boards and this was an important feature to me and it doesnt have one..
So now I will kill my project build thread and start the search for another truck.. maybe one that has not been altered already....
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
Re: My truck project has ended..
That sounds like a good idea, or with the times as hard as they are you could find a truck already built for half what you could build it for. I know that takes all the fun out of it, but its much faster and much cheaper
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
I hope I am hearing that the PO was an honorable guy and acknowledged his "misunderstanding" without too much resistance. I know around here, there are probably 30-40 rod, muscle, truck, etc. "projects" in the local thrifty saver paper (I think you can search them at American Classifieds on line) and on craigslist. I wish I had the money, in January there was a 62 Dodge two door sedan factory Max Wedge numbers matching in pieces for $1200, that sold in two days. I remember seeing a few AD and TF trucks already clipped. Good luck.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Wow allot has changed since this morning.. The P.O. called me and asked if he refunded half the money for the truck would I keep it..
I said yes... I just cannot see letting this one go for $600.... So the project is back on again... he is a good guy and I should be able to pick up a front clip out of a malibu for that if not less...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. Last edited by b00sted; 03-06-2009 at 01:52 PM. |
Commander Taco Bello
this may have been brought up in your build thread, but why not go the route of an S-10 frame? I'm sure you can pick one up for less than $600 easy.
![]() Join Date: Oct 2007
i agree with IvelDesigns the st rought is a good idea that is what i went. i picked a whole truck up for a $100.00. i bought a kit to mount the body instead of making my own though.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
Where can you get one of these kits?
here's one that i just found. It's not the kit i was thinking of, but it's priced the same:
http://www.e-zchassisswaps.com/1947.htm also, there are lots of threads in this forum where guys have built their own kits for much cheaper. takes time, and some skill, but saved a ton of $$. If it were me, and i had your truck, this i the route i'd go. I've never been a fan of cutting up a frame to begin with. |
you can buy the kits from http://www.ad-engineering.com/ and from http://www.e-zchassisswaps.com/index.htm. Not too bad as far as doing the job.
However, if you like doing a little extra work and getting into it fully check out this link....http://www.jalopyjournal.com/forum/s...ead.php?t=8491 That's the one I followed. Took me about 4 and 1/2 months to get it all done. That's with dropping in a v8, bags, 4link, and everything else to get it on the road and driving. I've got a build thread showing everything I've done. Any questions, just ask away. Later, Josh |
#10 | |
I know you probably here this allot but I have your truck as my wall paper on all 4 cpu's and my blackberry .... You sold me on the s-10 swap... Man I love that truck just the way it is...
#11 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=314296 is one link
http://67-72chevytrucks.com/vboard/s...d.php?t=300774 is another. Josh |
