Old 03-06-2009, 02:59 PM   #1
anton
anton's Avatar
difference between 71 and 69 c10?
As mentioned in an earlier topic I imported a 71C10 truck into Holland a few months ago. Now I have trouble with the department of transportation because the inspectors doubt if my VIN is correct. They found a sticker with a different VIN number in the glove box door then the VIN on the tag in my door post and on the title. The one in the glove box door says the truck is from 69 and I will have to convince them it is a 71 and not a 69 as the VIN number in the glovebox door says.
Now my question is if you guys can tell me if a 71 truck has specific differences with a 69 truck which are not interchangable. So f.a. is it at all possible to put a 71 front in a 69 truck, or change the lights on the fenders from the 69 to 71 lights, or put disc brakes on a 69 truck. Because I know disc brakes only came on trucks from 71 and later.
Or if you have other things that can prove 100% that it is a 71 and not a 69 truck.
I would like to add some pictures but cannot find out how that works. Maybe some other time !!
Thanks for all information !!
Anton.
anton is offline   Reply With Quote
Old 03-06-2009, 03:28 PM   #2
ksjh1316
ksjh1316's Avatar
Re: difference between 71 and 69 c10?
Yes everything is interchangeable with these trucks sounds like you got one that had some parts donated to a restoration.
There is one other place the vin is stamped on these trucks and that is the frame on the hump by the steering box. I would check there and see which it goes to. Hopefully it is the same as either the cab of the glovebox door.
Now for the inspectors the spid is just a piece of paper that is there and can come off.
ksjh1316 is offline   Reply With Quote
Old 03-06-2009, 03:33 PM   #3
texanidiot25
Eat My Rust
texanidiot25's Avatar
They should note that the one on the glove box door could easily have come from another truck when changing the glove box door. Go off the tags in the door jam for the cab's original VIN. It's a stamped piece of metal riveted to the truck, much harder to just swap for any reason in it's past than a sticker on glove box door that's held on by a few screws.
In Holland, what does the title stay with, the frame or cab?
texanidiot25 is offline   Reply With Quote
Old 03-06-2009, 05:11 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the rear view mirror inside the cab, in 69, the metal it is mounted on over the windshield is flat, in 71 it is a raised pad stamped in the sheet metal.
In 71, they went to a throttle cable instead of a metal rod.. not an easy conversion to do properly
I'm pretty sure 71 was the first year for a vent in the drivers side door jamb by the VIN plate.
Old 03-06-2009, 06:52 PM   #5
ERASER5
ERASER5's Avatar
71 - disc brakes
69 - drum brakes
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-06-2009, 07:02 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
The raised pad above the windshield for the rearview mirror, and the vent valves in the door jambs would be the best evidence for your cause because a '69 will not have them.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 03-06-2009, 08:13 PM   #7
b-rad
i know all 71 did not have the door vents why is that
b-rad is offline   Reply With Quote
