Old 03-06-2009, 03:52 PM   #1
kcackler
Need to move bed for sending unit install?
Just a quick question - Will we need to move the bed back to install a new fuel tank sending unit? I assume it will be hard to attach the fuel lines with the bed on the truck, but just wanted to make sure before tomorrow.
What's your preferred method of replacing the tank/sending unit?
Blue - 77 Chevy Scottsdale
kcackler is offline   Reply With Quote
Old 03-06-2009, 05:13 PM   #2
rddiaz
rddiaz's Avatar
Re: Need to move bed for sending unit install?
I got the bed off my truck right now , and you still can't get to the fuel pump so I would suggest just dropping the tank. You should be able to get to it without removing the bed.
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 03-08-2009, 04:17 AM   #3
Gregs71
I tried just "dropping the tanks", but had to lift the bed in order to unhook and reinstall the fuel lines.
Greg
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 03-08-2009, 09:48 AM   #4
kcackler
We did it yesterday and also had to lift the bed. There just no way we were getting the job done without moving the bed.
Old 03-09-2009, 12:03 PM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
kcackler, I wish I'd have found your thread a few days ago. I just replaced my gas tank, and this is what it took to get to the lines to disconnect/reconnect them. If you ever use this method, make sure you stack plenty of 2x4's between the box and frame, don't want anyone's head getting chopped off.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-09-2009, 12:09 PM   #6
kcackler
That's actually exactly what we did, Jason. It was the only way I could figure how to reattach everything.
Old 03-09-2009, 12:19 PM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
I removed my tank without raising the bed... its tight but it is possible.
Thanks,
Anthony
CLASSIC87' is offline   Reply With Quote
Old 03-09-2009, 12:25 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
I've pulled tanks by unbolting the brackets from the frame and cutting the hoses, but this was purely for removal.
To reinstall, my plan is to install a length of new hose onto the tank, snake it over the frame, then install the tank.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-09-2009, 02:57 PM   #9
babyJay
babyJay's Avatar
Originally Posted by Pyrotechnic View Post
...To reinstall, my plan is to install a length of new hose onto the tank, snake it over the frame, then install the tank.
Maybe the ideal plan would be to mount some sort of junction block on the inside frame rail? This would make for quick disconnecting and reconnecting in the future...to heck with those pesky ole bed bolts....
Jason
89 R3500 CC SRW
Old 03-09-2009, 09:33 PM   #10
vtwinsport
vtwinsport's Avatar
ditto on what pyrotechnic suggested. worked for me.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
