I like turtles...
To bag or Not to bag
hey guys, i have been lookin for a fullsize dually to slam, but i cant seem to find one in my price range, evidently everything is like gold now a days
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock ![]() Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
Low & Fast!
Re: To bag or Not to bag
For what you are looking to do it's about $1,200-$2,000 now if you are going for the best Air Ride Tech will run you about $3,000 or more.
Here is a long bed with body drop on air..
I like turtles...
thats an amazing truck!
![]() thanks
Old Heap Driver
Save up, buy what you can when you can. I'm a huge (new) fan of bags, and will never lower another vehicle by anything other than bags.
You can keep everything you mentioned and use bags, except the coils of course.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
I like turtles...
but how would i do the rear?
Old Heap Driver
Check this out................
http://www.ridetech.com/index2.html They have any combination you can think of. You can also go with a bag setup that keeps your leaf springs.
I like turtles...
sweet, thanks S10Fan!
Spear and magic helmet!
A lot of people have that air over leaf setup, including N2TRUX. Not the setup for laying frame, but works very well if you want to keep the bed of your truck intact and still drive around pretty low.
-- Will |
I like turtles...
yea i agree, but i dont use my bed now so i can aford to cut it up for it to lay out
Happy to be here
![]() Join Date: Mar 2000
Before you bag it, you should get everything else fixed. It's already low, so don't jump in to something you can't afford right now.
Air Suspension should only be done one way, and that is the "right" way. If you want to find yourself stranded beside the road, install a air system improperly and that's where you will be. Do it right, or don't do it at all.
#11 | |
It'd be alot cooler if you did
I have well over $5k into my suspension set up. |
#12 | |
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#13 |
A few more things to consider... there are several issues with bagging these trucks (or any truck for that matter) that people don't consider when they start a project like air suspension.
First off, lets talk about exhaust. You have to be very tricky with the routing, and chances are your existing system hangs down to low, which means an unanticipated trip to have some new pipes bent, throwing away long tube headers, and probably buying new mufflers while you are at it. Secondly, The front crossmember on these trucks is a major problem. The control arms hit the ground before anything else, creating a very, very uncool "backwards" rake. Not to mention that the first time you try to "drag it" (which I'm sure you will) the u bolts and the control arm flanges get melted off the front. Correcting this problem costs either a lot of money, time, fabrication, or all three. It drives me nuts looking at trucks that sit lower in the back because someone didn't take the time to do it right. Third, out back you're going to need a link set up... that's as far as I'm going with that because there are SOOOO many options it would take me a day to explain them all. Also don't forget valves, compressors, tanks, gauges, fittings, lines, switches.... Fourth, reliability.... your suspension is what holds your truck off the ground. So when it fails, you're not going anywhere. Not to mention you won't be getting underneath it to fix it. Fifth, lets talk about experience and research. It sounds like you have done no research, and also have zero experience doing suspension work. Also, that little zip box MIG welder you've been using to savage your sheet metal isn't going to cut it for frame welding. Scabbing some tail lights into your bedsides is one thing, but hacking your way to a bagged truck is a whole new ballgame, and very few people get it right. It takes time, lots of money, lots of research, lots of scratching your head, and a whole lot of downtime. Save your money, Jr. Finish the body work, paint the truck, put the front bumper on straight, and get some wheels that fit. I'm not trying to be harsh, but I think you need to evaluate where you are going with your project and look back at the job you've done so far. Have a good one. Last edited by smashingchuck; 03-07-2009 at 06:21 PM. |
#14 | |
Old Heap Driver
Bravo!
#15 | |
I like turtles...
#16 |
do what I did, leave this truck alone and drive the piss out of it. git another junk truck just for the frame, start haking away on that frame and if you get it where you are happy with the frame put this truck on that frame, there are alot of trucks out there that you could get for next to nothing that are rusted out or wrecked as long as the frame isnt bent. just my 2 cents!
#17 | |
Real Projects never die
WHered he go? account suspended?
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#18 |
I like turtles...
i just noticed that too, thats weird, where did he go??
#19 |
Looks like he got into a confrontation with someone. 48 hour ban.
Id say save your money right, do it once do it right.
