![]() Join Date: Feb 2009
Today, I took the heater out of the truck. I am going to replace the motor and clean and powder coat the box. I am a little confused on how it works. I had the radiator checked and it is clean and tight. This is a unit that is all inside the cab.
I have one lever which a fan switch and I can see how that works. What I don't understand is that it appears that the heater has constant heat from the radiator and coil in the heater box. When you move the one lever it looks like it is either defrost or heat out the bottom and back side. My question is, does it provide heat 100% of the time and the only difference is whether it is heat or defrost and the fan is on or off. Are the defrost and heat lever the same so that I only have two levers one for fan and one for heat and defrost. Thanks. |
Resistance is Futile
Re: Heater 1962
Mine has a small diverter on the tube, by the passenger side with a handle to open and close.....this is 64 however.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#3 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Heater 1962
That is correct
Re: Heater 1962
Captainfab, thanks, I guess it is a good thing the truck is going back to the Nothwest when I finsish it.
60-66 Nut
Re: Heater 1962
Back to the Northwest? Those recirculating heaters don't work for crap in the colder climates...BTDT. They are better suited for areas that don't get very cold....or much rain.
Re: Heater 1962
CaptainFab, so should I be looking for something different. Is there a choice for a 62.
#7 | |
60-66 Nut
Re: Heater 1962
If the truck is coming to the Northwest and is going to be driven in all weather conditions, I would suggest converting it to a deluxe heater. I think the owner would be happier.....that is unless he has already driven it in cold weather and is happy with it.
