OPP install
Ok... just got my windows from the group buy and having some issues installing.
I talked to Ben today he said to remove the 2 rollers facing the same direction, which I did. After replacing them with the new ones they do not roll in the C-Roller Channel on page 19. What am I doing wrong??? Does this C-Roller channel bolt to anything or simply connect two rollers? I think I'm missing a few nuts and bolts from the hardware bag. In my kit little baggy of hardware I have 4 rollers, only 5 bolts and 5 washers. No nuts No round vinyl hole covers. Looks like I'm missing 4 rollers. No felt tape. Anyone who can help make this a little easier any input would be great. Thanks. Last edited by NWD02; 03-06-2009 at 11:45 PM. |
VA72C10
![]() Join Date: Mar 2008
Re: OPP install
ttt for views
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Re: OPP install
ttt
Re: OPP install
Get to work
Under Construction
Re: OPP install
bttt
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
VA72C10
Re: OPP install
ttt
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: OPP install
I just found this. I am reading it to respond...
But there aren't any hole plugs, they don't work on 67-72's, and there should only be 4 rollers, 2 per side. The roller channel slides over the 2 outer facing rollers. It then bolts to the glass as shown on page 24 You should have 8 bolts though, 2 for the vertical guide and 2 for the roller per side.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 03-09-2009 at 10:36 PM. |
