Heated/power seats in old trucks?
What kind of wiring would it take to hook up seats like this in a 72 C10?Would you have to run it on a circuit breaker? Would the alternator have to be upgraded? Thanks for any help/ideas
http://greenville.craigslist.org/cto/1063876576.html |
454 MAKES IT ROAR
Re: Heated/power seats in old trucks?
We have a thing called an electric blanket here in the UK for your bed to warm it in the winter months....some guy modified one for a bench seat and layed it out between the seat foam and cover, did something clever with the electrics and put a toggle swith on the dash. Sorry can't be of any real help here but this made me remember.
http://www.amazon.co.uk/s/?ie=UTF8&k...l_30d7g0lhrn_b
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
resto body guy
i would run it through a circuit breaker "fuse" unless you want to see your wiring go up in flames!!
Someone on this site had a good page where he showed how he wired up some seats for his truck. I had the link can't find it now...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
alot of the newer Silverados with leather have heated seats. also the Mercedes Benz ML and GL SUVs have nice heated seats.
Also, 2003+ Pontiac bonnevilles have similar seats, but a little smaller, IIRC. I own one
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Looks good at 20-ft .....
My Buick LeSabre (about 2004 - 2005 year) tan leather split bench, with center console - bucket-style backrest seat with heat both sides & both sides electric, & built-in seatbelts ............. is a pretty-comfy seat, & has the desirable thin-backrest, & is about the right width for the truck. And shame on me ---- I don't yet have it installed yet.
It has an approx 10-ga wire which supplies power feed to both driver & passenger side of the electric seat-tilt & travel adjustments, fed thru the driver's side seat, with a quick-disconnect plug-in connection. Factory service manual showed the orange wire was hot, & black was ground, fused thru a 30a fuse to operate the seat & also to provide power to the heaters. Dealer said: "Most GM seats use the orange & black power combination." Both my Jeep Grand Cherokees also use a 30a fuse for the power seats. I bought a 10 ga pigtail from the local O'Reilly's store which has an inline fuse socket that would fit the bigger full-size 30a fuse, & I plan to use that to direct-wire the seat in, with the fuse under the seat after it's in ........ just whenever I get off my dead-a$$ & go ahead & get it installed. However, the heat settings were wired into a sensor variable temp setting of some kind which was built-in on the dash of the wrecked car that the seat came out of. Not yet sure how I'll deal with that heater-adjustment issue. Not knowing how to do the heat hookup's what has been keeping me from getting it installed. Last edited by 68shortstep; 03-07-2009 at 03:23 PM. |
