Old 03-07-2009, 12:47 PM   #1
harrishawk
Help with identification of part
This is attached to my distributor (?) near the back of the engine on the left side of the air cleaner. It has a hose that attaches to it that has rotted into. The truck is an 84 Silverado 8 cyl and runs okay. Just need to know if I need to replace the hose. Thanks
harrishawk is offline   Reply With Quote
Old 03-07-2009, 01:06 PM   #2
drifter101
Re: Help with identification of part
its the vacum advance for your dist.
drifter101 is offline   Reply With Quote
Old 03-07-2009, 01:08 PM   #3
78 Chevyrado
x2 I'd replace the hose, it will make it run better and more efficiently plus right now it's a vaccum leak.
78 Chevyrado is offline   Reply With Quote
Old 03-07-2009, 01:08 PM   #4
harrishawk
Thanks. I appreciate the help.
Old 03-07-2009, 01:11 PM   #5
drifter101
yeah replace the hose, prolly cost a couple of bucks
Old 03-07-2009, 01:41 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
that will affect fuel mileage,replace the hose
powerdriver 1958 is offline   Reply With Quote
Old 03-07-2009, 06:25 PM   #7
harrishawk
Thanks so much - fixed for $2.50! I have another item - if you don't mind
Old 03-07-2009, 10:18 PM   #8
sierra4x4
sierra4x4's Avatar
That hooks to a valve just past your exhaust manifold thst closes when the engine is cold so the exhaust has tho go through a passage in the intake manifold and out the drivers side exhaust manifold so the intake warms up faster. It is a good thing to have as long as its hookes up right and works. I once saw one that was hooked up wrong and every time you stepped on the throttle it would close and cause a power loss.
sierra4x4 is offline   Reply With Quote
Old 03-07-2009, 10:54 PM   #9
harrishawk
Thanks - I'll check for the valve.
