Old 03-07-2009, 01:51 PM   #1
ed2552
ed2552's Avatar
Ignition Wire from Fuse Block
Hey guys, I'm finally back, a little bit. I want to get my 67 back up and running again, and this is the only thing in my way. Last fall, when I installed my new distributor, the wire from the fuse block burned off, and is keeping the truck from running. I also need a new coil. What's the proper way to wire up an external coil HEI setup? Thanks for all the help.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-07-2009, 02:34 PM   #2
OldCreek
OldCreek's Avatar
Re: Ignition Wire from Fuse Block
That wire, if original, should be a resistance wire. You'll need to pull that wire/connector from the harness and run a new wire (non resistance) from the hei to the box. The connector is replaceable itself, as sometimes it gets damaged when pulling it out of the box/harness. But with care, you can reuse the connector.
I'm not sure if you definately need a fuse inline or somewhere else on that harness for this.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-07-2009, 03:22 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I used 12 guage wire from firewall to distributor.
For the connector on the firewall, if you can't salvage the old one, see if NAPA has pn NW 725145. That's the one you need.
68gmsee is offline   Reply With Quote
Old 03-07-2009, 04:24 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Try looking here.
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
Here.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346 This is a factory looking set-up with part 's
and here.
http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-07-2009, 05:32 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You need to explain what the wire is and where it originates IOW what was it connected to in the fuse block. What brand is the external HEI coil and does it require a resistor or does it run full 12 volts. It should have a positive connection for the ignition wire and another connection for the distributor.
I think the other guys missed the bolded part in your post.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-07-2009, 11:25 PM   #6
ed2552
ed2552's Avatar
Well, we messed something up, because I tried hooking the coil up to direct power, and the coil started smoking..... (no one was hurt in the process of this)
I believe it's a brown wire. I guess I can't get to it for a week, because my parents are having people over in the shop, so I can't make a mess, and I have to clean up in there first. It doesn't help that the wires are a rats nest of cobbled together crap.
