Seņor Member
Anyone work Lexan?
I'm looking to get some taillight lenses machined (see attached). The 3D aspect of them is meant to be a bit of post-modern '59 Caddy... that is, a pair of curvilinear arcs from the base to the top where they create a point... but along the whole length of the lens so that the 'point' is really an edge down the length of the lens. I've included a cross-section and end profile sketch in the attachment that may clarify. I'm looking for someone who can make me a pair of these, flame polish them, and then lay them up on a piece of prismatic clear that's bigger than the lens so they can be back loaded through the sheetmetal hole without falling through. I can provide more details to whomever might be able to make these for me.
Here's a shot of the truck now. Taillight lenses are in the slots now (backloaded as described above), but they're a flat surface. I need to add some dimension and character to them... hence the request. Anyone?
Seņor Member
Re: Anyone work Lexan?
A few better pics of what's in there now...
Seņor Member
CAD'd thanks to slammed67
No just need to find someone to cut it.
Seņor Member
New lenses are cut. But still need LOTS of sanding and polishing. Pics from my craptastic phone cam.
Cool. Who did ya' find to do them?
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Those are cool....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Seņor Member
I wet sanded these today with 220 to get the tool marks off of them. Now to progress up to the 1000 grit range, then bust out the buffing wheel.
