Old 03-07-2009, 07:48 PM   #1
MarkMark
MarkMark's Avatar
pic request. short pump accessory routing and mounting
Im in the process of changing from a long to a short pump set up. I have everything off, and have the short pump on. I need some help with how all of the accessory brackets mount. And can I use my Power steering pump without the external reservoir from my long pump setup? I will be running power steering, and A/C.
-Mark
MarkMark is offline   Reply With Quote
Old 03-07-2009, 08:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: pic request. short pump accessory routing and mounting
big block engine?
Old 03-07-2009, 08:36 PM   #3
MarkMark
MarkMark's Avatar
Originally Posted by Longhorn Man View Post
big block engine?
yes. cant believe I left out that crucial bit of info.
Old 03-07-2009, 09:41 PM   #4
franks72
Junior Member
franks72's Avatar
I dont think your going to be able to use the long water pump, power steering pump. If you dont want a reservoir I think your gona have to go with an aftermarket unit. Why not use the factory pump with the reservior? There are always guys selling the brackets and pumps on here..
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 03-07-2009, 09:44 PM   #5
Longhorn Man
frank, the stock big block set up on these trucks do NOT have a resevior.
I doubt you can use the assembly you have... be ready to shell out some cash too... this stuff is NOT cheap.
Old 03-07-2009, 10:12 PM   #6
MarkMark
MarkMark's Avatar
I have all the short pump brackets, bought them from Leddzepp. The power steering pump i received from him has an external reservoir. I'll take some pics tomorrow.
I just need pics to see how they all mount.
Old 03-08-2009, 10:07 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Here you go Mark...hope this helps.
leddzepp is offline   Reply With Quote
Old 03-08-2009, 11:54 AM   #8
franks72
Junior Member
franks72's Avatar
Opps ,forgot to add the word ( external ) in the sentence, if you dont want a (external) resevior... sorry...
Old 03-08-2009, 01:32 PM   #9
MarkMark
MarkMark's Avatar
Thanks, That will get me moving forward.
Old 03-18-2009, 04:58 PM   #10
MarkMark
MarkMark's Avatar
Im lost as to where the power steering reservoir mounts. Can any one help??
Old 03-18-2009, 05:30 PM   #11
Johns70
Johns70's Avatar
mounts to the inside of the driver fender towards the front, close too the corner brace
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 03-18-2009, 05:40 PM   #12
MarkMark
MarkMark's Avatar
To a bracket or directly to the fender. I cant seem to find any thing that looks like it will line up with to bolt in.
Old 03-18-2009, 10:02 PM   #13
Johns70
Johns70's Avatar
the res. should have a braket on it with two holes. on left fender, right by the windshield washer res. there should be one hole and you will have drill the other. hope this helps
Old 03-19-2009, 06:29 AM   #14
DANTIP
DANTIP's Avatar
Here are some borrowed photos that show the location of the divorced reservoir. As mentioned before there are two welded nuts on the back of the reservoir bracket that accept bolts through the inside of the front fender.
DANTIP is offline   Reply With Quote
