Old 03-07-2009, 09:38 PM   #1
Eighty-6
sport bumper ?'s
I just finished mocking up the sport bumper i received from LMC and there's a big slot in between the bumper and the bed. I thought i read on here that several of you have pulled the bumper in. Can someone post how much we can pull the sport bumper in with out it affecting tailgate functionality and also how did you do it? Pics would help if you have them.
Eighty-6 is offline   Reply With Quote
Old 03-07-2009, 09:47 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: sport bumper ?'s
BoatPuller did it to his, Hope he can post something for ya..
tvblazer78 is offline   Reply With Quote
Old 03-07-2009, 09:59 PM   #3
sierra4x4
sierra4x4's Avatar
Their is a filler panel thet fits in there to fill the gap some are plastic and some are metal. I think Blazer ones are the same. But, I know that Suburban ones are different.
sierra4x4 is offline   Reply With Quote
Old 03-07-2009, 10:33 PM   #4
Eighty-6
I saw that in the LMC catalog but it seems like they are only long enough to cover the brackets. To me it doesn't look good with the gap that big now if the filler panels run the width of the bed that may work.
Old 03-08-2009, 08:46 AM   #5
OJOE
Crew Cut
OJOE's Avatar
i like to move mine in like this
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 03-08-2009, 08:57 AM   #6
rod86
great southern land
rod86's Avatar
OJOE - how did you move it forward? did you just slot the bumper bracket holes an slide futher forward?
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 03-08-2009, 08:59 AM   #7
Eighty-6
Now that's a sweet looking truck . How far did you bring it in?
Old 03-08-2009, 09:12 AM   #8
OJOE
Crew Cut
OJOE's Avatar
while building the truck i had to build a hidden hitch because of a blazer gas tank install. i also modified the bumper brackets to move the bumper in.i welded this all in.
you can pull your bumper in until it looks good to you (about 1/2" from bed corner) and weld in place or redrill and use bolts. be sure to check clearance on tail gate.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 03-08-2009, 09:20 AM   #9
bigblock73
yeller
bigblock73's Avatar
If you have the HD (longer) leafs, it isn't so simple. The ends of the brackets will have to be trimmed off in addition to drilling new holes or elongating the existing.
bigblock73 is offline   Reply With Quote
Old 03-08-2009, 09:35 AM   #10
Eighty-6
Thanks for the info guys. This helps point me in the right direction. I'll let you all know how it turns out.
