Old 05-15-2002, 10:48 AM   #1
tracy
Post lift application
WILL A LIFT OFF OF A 72 BLAZER FIT ON MY 72 3/4 TON 4X4??????????
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot!
tracy is offline   Reply With Quote
Old 05-15-2002, 11:28 AM   #2
MJN
MJN's Avatar
Post
They should be the same. Easy enough to measure between the spring eyes for the length. Front u-bolts will work but rears won't, blocks will work not sure about rear spirng packs.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-15-2002, 12:14 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
yes it should
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 05-15-2002, 03:08 PM   #4
Baradium
Binder Rep
Baradium's Avatar
Post
so you want to convert your 3/4 ton to a lifted 1/2 ton?
Baradium is offline   Reply With Quote
