PS Pump Mounting Question
Here's a little background. My '75 1/2 ton 2wd originally had a 250/3-speed and was converted to a 350/TH400. Also, the guy that converted it put an Edelbrock intake on it (and painted it blue
![]() Anyway, I don't think the bracket on there is right. I tried to replace the belt yesterday and when I tried to pull the old belt off, I had to totally unbolt the pump. There is no room for the pump to slide down to loosen the belt without unbolting the pivot bolt. The belt I got (same number as old one) was too tight and I couldn't get it on there. It was slightly shorter than the old one probably do to the old one being stretched. It just seems like there should be more adjustment room for the pump to slide back and forth. Here are the pics of the PS pump and how it bolts up. The pivot bolt goes through the waterpump which seems to be right. However, the long bracket that bolts into the intake doesn't seem right. I don't have AC and the belt just goes from the PS to Crank pulley. http://www.shelbournes.net/trucksite...s/ps_pump1.jpg http://www.shelbournes.net/trucksite...s/ps_pump2.jpg http://www.shelbournes.net/trucksite...s/ps_pump3.jpg Does anyone have a picture of how their PS pump is mounted? Also, does this seem right? How should it be mounted and with what bracket? Thanks in advance!!
Scott Shelbourne Last edited by BigRed; 12-16-2002 at 03:54 PM. |
bracket
check to see if there is a bolt on the bottom of the pump bracket. my 78 has one that has to be reached from under the truck. looks like you have some #^%#%^ engineered brackets there bud. You may need to take that "custom" one off and reinstall it after the belt is on with the other nuts tight to hold the tension.
http://members.cardomain.com/chevyjeff 57 2 DOOR HDTP 82 CORVETTE 90 V10 BLAZER 97 REGAL LSR 2100 (BOAT) |
#3 | |
Re: bracket
Scott Shelbourne |
think you have some mismatched brackets. I would try to find some off a truck at a salvage yard. those ones you got probably came with that motor whatever car it came out of. You will have to do a little modification wiht spacers to get the bracket to work with the headers. Too bad 2 weeks ago I threw out a bunch of these type of brackets..
You get what you pay for
![]() Join Date: Dec 1999
You have for sure got a rigged mess.
Here's close to what it should look like. I modded my stock bracket a little because of my headers. http://www.73-87.com/photos/old/bracket1.jpg http://www.73-87.com/photos/old/bracket3.jpg
Mike 1985 Chevy C-10 |
#6 | |
Scott Shelbourne |
pkbinplano
What about a longer belt ?
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
the bracket that is bolted to your intake to the pump bracket is a alternator bracket!!!!! correct me if im wrong. who ever did this, didnt want any brackets bolted on those shinny new headers!
I'm back with 2nd truck!
Looks like how I did mine before I got the old bracket that I needed. Scott I got a bracket from the junkyard and made it like Swervin's. It's the AC bracket that mounts to the P/S pump that Swervin's showing. If anyone has one you might grab one.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#10 | |||
Thanks for the responses.
![]() Quote:
![]() Quote:
I knew I probably had a rig-job. Does anybody have one of these AC brackets? If so, email me at scott_shelbourne@yahoo.com or PM me. Also, if anyone has the specs on one, I can have one made. Thanks!!!
Scott Shelbourne |
My other Love
that sure looks a lot different then the bracket on my 77. One side of the bracket mounts to the water pump. the other side mounted to the manifold. Of course now i have headers so there is a spacer between the bracket and the header.
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Gentleman Jim Driver
Here is the GM exploded parts pic of the A/C brackets. This picture leaves out the P/S pump brackets, but at least piece 18 is shared by the A/C Compressor and the P/S pump. Looks like piece seven is the one missing from your setup.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 12-17-2002 at 01:47 AM. |
