air conditionning help?!?!
i couldnt find the right section to post this in,so sorry if its in the wrong area.
im my 1967 c10,its not a factory a/c model. whats the best way to do ANY type of air conditioning in it 'ON A BUDGET" it gets to 120 here in the summer(mohave valley,arizona) so i need it. thanks ![]() Last edited by dmartin1; 03-08-2009 at 12:35 AM. |
Moderator
![]() Join Date: May 2007
Re: air conditionning help?!?!
Unfortunately, there is no way to do A/C "on a budget"....good luck
Yeah non-factory A/C = Throw budget out window. There are several companies that make A/C systems, or you could piece together a factory style system, but they're all going to cost over a grand by the time you're finished.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
it can b done on a budget but the budget needs to be in the neighborhood of $1200
Moderator
Can't ReMember
Here's a link from FAQ.
Vintage air in a 1967 C-10 http://www.67-72chevytrucks.com/vboa...d.php?t=249479 More at the bottom of this link http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
True story, lol. Figure at least $1200 for it.
Rods
![]() Join Date: Nov 2002
nahh you can do if for less but it will not be factory. andy you will spend lots of time at the junk yard. you can put together an ac sys from some cars from the 80 to early 90,s you can have the hoses made. I work at a mack deal and we can make hoses there. not sure about where you are.
Got my A/C setup from Ebay for $66.66.
You can probably hang one of the old style Mark IV style (brand not out of the car) under dash units in the tru Bck and get the brackets to mount the compressor on the engine for a somewhat reasonable price but it will take up a lot of room and may not appeal to everyone. But it will get the inside of the truck cold.
I'd vote for one of the kits sold by Vintage or one of the other companies that makes ac units for these trucks. Some guys have converted some of the small foreign car units to work but I am not sure which ones are the easy ones to do that with. Ah, Ha, I have a small foreign car sitting in the yard with a very good heater/ac unit and the car is headed for the scrapper. |
please look over the rules, as a non subscriber you are not permitted to request parts.
Junior Member
![]() Join Date: Nov 2006
Hey dmartin1,
check this thread out. http://67-72chevytrucks.com/vboard/s...d.php?t=301553 Then figure out what "budget" means and which way you want to go. I may have some stuff for you for just the shipping. Welcome to the board - this bunch is GREAT! |
#13 |
Rods
just read it. love it.im not sure what its worth but I have an a/c from my 72 gmc
#14 |
Junior Member
Hey Dylan,
I think this link explains how to support the board. Worth it a 10 times over. http://67-72chevytrucks.com/vboard/s...d.php?t=139629 |
#15 |
Rods
nevermind...im slow and its monday
#16 |
you can find some cheaper ac units for around 6-800 range, nothing fancy or factory but at 1 120 im sure you wouldnt care. just hit up some swap meets
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB, "some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno |
#17 |
425hp409
![]() Join Date: Oct 2008
If your truck is a small block I have an under dash unit that I just took out of my 68. I am installing a big block with factory air. The truck was my Dad's and he had the unit installed in about 1970. It will freeze your ---- off by running R-12. I haven't ran it with R134, but I bet it would work fine. I am in Texas where it gets plenty hot and humid and it worked great. It is complete with condenser, hoses, compressor and brackets, pulleys, belt, under dash unit and most importantly an obsolete heater adapter duct that was required for a proper installation. Let me know if you are interested.
Charles cdhaley@friscoauto.com 972-335-9823 |
#18 |
![]() Join Date: May 2002
here's a link to most of the equipment needed, on ebay:
a/c equipment
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#19 |
whatever you go with use an R-134a system instead of R-12.R-12 costs TOO much.
