Old 03-08-2009, 08:15 AM   #1
mothertrucker424
mothertrucker424's Avatar
eaton rear disc conversion
i ahve a eaton 52 i just ordered my rear disc brackets and i now need to pick up rotors and calipers pads haoses and lines can some one direct me in the right direction i know i need 3/4 d44 parts
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 03-09-2009, 08:55 PM   #2
mothertrucker424
Re: eaton rear disc conversion
i ordered ruff stuff caliper brackets i'll have a full write up for a eaton tear down to installed under truck
Old 03-09-2009, 09:09 PM   #3
tractor1963
The parts you need are from a 1976 or 77 3/4 ton GM 4x4 truck,rotors and calipers will work with those brackets.I hope this helps.
tractor1963 is offline   Reply With Quote
Old 03-10-2009, 08:17 PM   #4
mothertrucker424
it does and are 1/2 caliper the ssame as 3/4 ton calipers?
Old 03-10-2009, 08:22 PM   #5
tractor1963
No,I dont think they are,I know the brake hoses are different,the banjoe bolts are a different size from 1/2 to 3/4 ton.I know the part #'s are different if you look them up.
Old 03-10-2009, 08:35 PM   #6
mothertrucker424
do i use 3/4 ton hoses too?
Old 03-10-2009, 08:39 PM   #7
tractor1963
Yes,they will work with the calipers.
Old 03-10-2009, 08:43 PM   #8
mothertrucker424
i'll have pictures and questions soon thanks
Old 03-10-2009, 08:46 PM   #9
tractor1963
Hey no problem,glad to help
Old 01-06-2011, 12:07 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I tried searching. How'd this work out for you?
66 C20 Service Truck:
Old 01-06-2011, 12:41 AM   #11
LostMy65
LostMy65's Avatar
Here's a link to another mfg:
http://www.tsmmfg.com/2630Eaton.htm
I'm going with the ruffstuff, but this link gives info on e-brake:
(2) 76 - 78 El - Dorado rear calipers with parking brakes, pads, and mounting screws.
Old 01-06-2011, 08:03 PM   #12
swamp rat
swamp rat's Avatar
Subscribed!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
